FAST EFI XFI Engine Management System GM Chevy L98 TPI
I am running the Acell Gen 7, along with the dual sync dist. The learning curve was very steep, not because it was hard, but because if you do not take one of thier classes, there is now where to learn. I found someone to teach me and at this point in time I would say I am really happy with the system and find it far superior to burning chips. Tunning on the fly on a dyno, or at the strip it is great. I dont have much knowledge of the Fast or some of the others in how easy they are to tune, but unless someone is willing to teach you what to do, and why, these system will frustrate the hell out you. Once you reach a point of why and how I would not be without one. I would like to see just how easy it is to tune with a Fast system for someone with out any knowledge, I know the Acell was hard. I have yet to see good documentation with the Acell, and ther-in lies the problem.
The FAST XFI System is nice Sammy.
I have know guys to use it on their 9 second Buick Grand Nationals and 5.0 Mustangs dipping in the low 8's.
My buddie Crazzie Eddie is running 8.20's with the stock Ford ECU yet.
Its Vortech blown with 28lbs of boost.
He tells me the FAST XFI or other aftermarket systems are a waste of money for him.
For him I agree.
I am amazed at the resourcefulness of many C4 owners and home tuners here on C4.
Using stock ECM's yet and flying with them.
If you have the $$ buy the FAST XFI.
From what I can see, its just a luxury till you break out of the 9's 1/4 mile.
I hear FAST XFI is very user friendly, a big plus going for it.
Brian
For him I agree.
Brian
There is a New FAST XFI EFI system out that I only seen in the back of Racing Trade- machinist catalog dated for this month-April.
I spotted the system while visiting a friend in his engine machine shop last month-March.
I believe its called the FAST XFI plus.
Besides all the usual features, this system will fire up to 16 fuel injectors, does data logging, and unlike other systems it works like the OEM ECM does.... It does Block Memory Learns or BLM's.
It automatically learns the spark advance and fuel trim tables as you drive your car on the street or at the track.
Its packaged in a Black Anodized case.
A quick check on Summit Racing.com,
I don't see the NEWEST BLM equipped FAST XFI EFI system.
Anyone else out there have seen it or are using it right now?
Brian
Brian
Brian
Brian
BLM is a correction from the base tune. XFI 2.0 actually creates the VE table (base tune) as you drive.
Bruce!
Thanks for the excellent feed back!!!
I realize that this post is about 5 years old, but the topic is right up my alley!!! I have fabricated a custom 1955 truck frame, C notched it, & then taken the C4 chassis and rolled it under my now lowered 55 pick up. In other words I have a swapped bodies from a 1988 C4 , ifs, and irs, and an L98 Corvette with a Chevy Truck body... masking its true C4 identity. Here is my burning question. Currently there is no wiring harness. I want to use a self adjusting EFI computer to run the L98 engine. I am told it is very efficient and dependable once installed. What sensors do I need to connect seeing I will be building my own harness. I am a fish out of water at this time as the last hot rod i built was back when no connections were required (just a power wire, to the ignition & all gauges were mechanically monitored no computer or sensors). I'm sailing into uncharted waters. Is it as simple as running one wire to each sensor, plus installing a proper fuel pump system with a return fuel line? What about connecting the L98 cooling fans?. In other words, will the stand alone EFI have basic instructions saying where to run the wires and thats it?? I want to purchase the EZ-EFI Fast electronic universal tuned port EFI and get this engine running ASAP!!! But I don't want to spend the money only to find it to be way too complex. The sales at our local hot rod shop says "no problem, its really EZ!"... he is a very nice person, but has no mechanical expertise!
Haltech GM Sport
Haltech has a simple Sport GM ecm direct swap out ecm for Corvette,Firebird, Camaro and others 1986-1989. Has anyone got any experience with them?
http://www.haltech.com/product/sport-gm/
