C-4 Calipers Sticking
Old Mar 29, 2009 | 05:50 PM
DDJJ's Avatar
DDJJ
6th Gear
Default C-4 Calipers Sticking
Has anyone had problems with both the front Calipers sticking? Within 5-10 minutes they release.
If you have what did you do to correct the problem.
Old Mar 30, 2009 | 04:13 PM
IRAraid's Avatar
IRAraid
Default Sticking calipers
As a diagnostic, lift the car onto jack stands, press hard on the brakes then try to spin the wheel. If it's 'stuck' open the brake bleeder screw then try to spin the wheel. If it frees up quickly, the brake hose is bad. If it remains 'stuck' when the bleeder is opened, the caliper is shot.
Never had this on my Corvette but several other GM cars/trucks had the problem.
Hope this helps.
Old Mar 30, 2009 | 04:18 PM
Demonic85's Avatar
Demonic85
If the caliper isnt working and you've done raid's test, its cheap and relatively easy to just rebuild the caliper itself.
Old Mar 30, 2009 | 04:24 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have had this problem before on another car. When the hose gets old it will tend to collapse on itself and act like a check valve. It will let fluid in to the caliper to brake but does not let the fluid back out to to release the caliper.
Old Mar 30, 2009 | 04:53 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I've seen it before too, not specifically on C4s but...
Old Mar 30, 2009 | 05:00 PM
383vett's Avatar
383vett
Wait a minute. I thought the op said both front calipers were sticking. What are the odds that both front hoses collapse at the same time. Seems like a master cylinder to me (or abs system if he has one).
Old Mar 30, 2009 | 09:53 PM
onebighitter's Avatar
onebighitter
It seems like corrosion biuld up on caliper slides to me. Take caliper slides out and clean them. Parts $0 labor hour or so. That is what I would try, happens on import vehicles alot
Old Mar 31, 2009 | 07:42 AM
runner140*'s Avatar
runner140*
As Demonic85 posted, a caliper rebuild is quick and cheap.
To C-4 Calipers Sticking
