where can I order these and make sure i get the ones made by dana so i dont get any whine? also where do I order the gear to correct the speedo? im going to do this install myself at the shop i work at, with the help of a guy i work with who is a gm master tech and is very familiar with c4s.
any way if i could get some good links to shop at and maybe an install kit and a list of whatever else ill need
Not trying to be a wise guy, but if your friend is a Master Mechanic for GM, it would be better if you asked him, he probably can save you some money, and aggravation too. Good luck, I wish I had a GM Master Mechanic as a buddy.
I bought my Dana OEM 4.10 gearset from a forum member that worked at a GM Dealership. Unfortunately, he no longer sells the gears. I think now most buy the Dana Viper 4.10's.
This Dana "Super 44" 4.10 gear set (48084/48085) with a six bearing/three seal build kit with shims $500 shipped. Most ring/pinion gear set bearing install packages include only the pinion seal with 4 bearings. My package will include the short axle bearings with seals. A complete build!
The speedometer correction gears are available from here:
I'll include the only other part required for the install which would be the transmission rear seal which you will need to install the transmission drive gear.
If your '92 is a "high miler" it might be the "right time" to do u-joints!
