Will these bolts work ? (lowering)
Old Mar 30, 2009 | 11:13 PM
Noobster's Avatar
Noobster
From: My Give A Dams Busted The Bend Me Over State N.J
Default Will these bolts work ? (lowering)
Hi im trying to lower my 88 more then the 10 " bolts they sell with the kits. Will 1/2 x 12 bolts work ? Here are the one's . Thanks
http://cgi.ebay.com/ebaymotors/1-2-x...Q5fAccessories
Old Mar 30, 2009 | 11:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
They will work, however, they are a 1/6'' smaller in diameter, than stock. I would assume that they are grade 8, being they are meant for a heady duty application, but I would contact the seller, if your set on getting these.
You should be able to find 14 mm or 9/16" grade 8 bolts online if you can't find them locally. I ended up buying alloy threaded rod from Acklands and cutting to size.
Old Mar 30, 2009 | 11:38 PM
Noobster's Avatar
Noobster
Thanks ive been looking and looking. I found some for 80 bucks. Way to much to spend on bolts !
http://www.vbandp.com/detail.aspx?ID=383
Old Mar 31, 2009 | 07:48 AM
jon0108's Avatar
jon0108
also, those on ebay you posted look like they dont have nylock locking nuts.
I just lowered my rear with the 10 inch bolts. Managed to get the rear from 29 1/4 to 27 1/2 inches. I'm happy with it now. It may only be an 1 3/4 inches but it looks like alot more. My avatar shows my car at the original rear height.
Old Mar 31, 2009 | 01:52 PM
Noobster's Avatar
Noobster
I went for it ! Ill give them a try.
To Will these bolts work ? (lowering)
