Digital Dash problems
Old Mar 31, 2009 | 01:04 PM
ARaney2175's Avatar
ARaney2175
2nd Gear
Default Digital Dash problems
This past dec. I got an 84 corvette for my birthday from my boyfriend who had it before. And I love driving it around, but there's a problem.
When your driving it around and hit a rough spot in the road or a bump. The dash goes out like completely you don't see anything. And after awhile it comes back on.
I was wondering if this was a problem with my display or a ground wire or something.
Old Mar 31, 2009 | 01:46 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Could be a ground. Does everything completely go out or just a section?
Old Mar 31, 2009 | 02:00 PM
WW7's Avatar
WW7
Could be a ground, but it also could be that the solder joints are starting to break on the circuit board. Im having the same problem with my 89, but it doesn't happen often enough yet to send my cluster in. If you send it into the company at the link at the bottom they are having a sale right now an instead of $225.00 they will overhaul the whole cluster for $185.00. This sale is on until June so if you find out you need a rebuild, send it in before then, Im told this company does excellent work..The ground wire on my 89 is on the back of the drivers side head, it may be the same with your 84 but Im not sure...Good Luck...WW
http://www.corvettedashclusterservice.com/index.html
Old Apr 1, 2009 | 08:35 PM
ARaney2175's Avatar
ARaney2175
2nd Gear
it goes completely out, not just sections
Old Apr 1, 2009 | 09:32 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
Sounds like a deal. I payed close to $400 for an exchange unit
Old Apr 1, 2009 | 09:40 PM
coxjajb's Avatar
coxjajb
I had an 84. The ground is behind the left side head. My ground was loose and would cause the dash to go black.
Old Apr 1, 2009 | 10:19 PM
tonylong's Avatar
tonylong
I have a similar problem with my 89's digital cluster.
Sometimes the right side gauges are too dim, thumping with my fist will brighten them back up.
Sometimes the left side will go black - thumping does no good, but driving over tracks or potholes will set them right again.
This has been going on for years.
Old Apr 28, 2009 | 08:47 AM
Big Rat 427's Avatar
Big Rat 427
I am heaving similiar problems, intermitten complete loss of dash. I am confused about location of the ground to check. When everyone is refering to left (drivers) side head. Where is this ground. I am trying to find it to check.
thanks.
Old Apr 28, 2009 | 10:23 AM
engle1147's Avatar
engle1147
Tony,
Sounds more like the bulb and/or bulb sockets connections are poor intermittent....replace the bulb and bulb sockets.
with BADDUCK if everything goes black and the both turn signals come on at the same time when everthing else is "blank"
OP's issue sounds like a bad ground...most bad ground connections are within the cluster it self or with the cluster's main connector. Remove the cluster and clean the pins and connections and ensure they are fully seated before chasing elusive engine compartment grounding points.
Old Apr 28, 2009 | 11:57 AM
twotone84vette's Avatar
twotone84vette
I had the same problem with my 84. I had cracked solder joints. Followed the instruction on the attached link 3 years ago. No problems since.
http://www.batee.com/corvette/dcrg/
Hi Big Rat 427. I bought your wheels. :-)
Old Apr 28, 2009 | 02:53 PM
Gryz88's Avatar
Gryz88
If you do follow those instructions, watch carefully on the reassembly, I cracked one of my LCDs by not seating it properly 2 weeks ago.
I had the same problem as you, it eventually evolved into perminatly losing the brightness.
To Digital Dash problems
