Real quick, easy question
Old Jan 30, 2002 | 02:39 AM
dtorc4's Avatar
dtorc4
Default Real quick, easy question
Just to make absolutely sure, the flexplate for 85 700r4 is 168 tooth, right? Thanks. :cheers:
Old Jan 30, 2002 | 03:44 AM
dtorc4's Avatar
dtorc4
Default Re: Real quick, easy question (dtorc4)
ttt
Old Jan 31, 2002 | 03:33 AM
ol,RJ's Avatar
ol,RJ
nope, its listed as a 153 tooth. I'm pretty sure the 168 won't fit into the 700r4
sorry, hope you havn't bought one yet.
Old Jan 31, 2002 | 11:42 AM
dtorc4's Avatar
dtorc4
Default Re: Real quick, easy question (ol,RJ)
nope, haven't yet. Almost did last night, but decided to wait for an answer. Thanks RJ! :cheers:
Old Feb 1, 2002 | 02:05 AM
ol,RJ's Avatar
ol,RJ
I did some more looking into it,
its really a clouded issue, some years are 168tooth some 158 (this is from catalogs like jegs ect.).
I still think the vette will take a 158.
the reason I say that is because my 86 manual trans takes a 158 from the factory. I used a 168 for my new motor, It was too big for the stock bellhousing and combined with a lakewood bellhousing it does affect the ground clearance. it also made a starter change nessesary. so I think the 158 was used for packaging and clearance.
lingenfelter has a 153 tooth flexplate listed for stroker motors.
you will need to know if you want internal or external balancing, and it's best to have it balanced with the motors rotating assembly.
To Real quick, easy question
