Rough Idle on a cold startup
Old Apr 1, 2009 | 02:13 AM
espop125's Avatar
espop125
Default Rough Idle on a cold startup
I have a 1986 vette and when i start it cold it starts very easy but if i don't immediatly give it a little gas for a second it stalls, and if i do it has a rough idle for approx 3 or 4 minutes and then it runs normal. Also when its in its rough idle and I rev up the motor it pops through the engine. Any help? I have checked fuel pressure and its fine I also changed the fuel filter and i am about to do the plugs wires cap and all that but these things are not that old anyway. Anyone have any more suggestions?
Old Apr 1, 2009 | 02:28 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Pull the codes, if any.
Old Apr 1, 2009 | 07:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The cold start valve might be a good place to start.
http://members.shaw.ca/corvette86/Co...rt%20Valve.pdf
Old Apr 1, 2009 | 01:39 PM
espop125's Avatar
espop125
no codes at all never kicks the service engine light
To Rough Idle on a cold startup
