Flowmaster muffleer question
Old Apr 1, 2009 | 12:34 PM
lltrevino's Avatar
lltrevino
Default Flowmaster muffleer question
Is there any truth to Flowmaster redesgning a SPECIFIC muffler for the C-4? I read that a redisgned muffler was made specific for the C-4 to combat resonance. I was wondering, because, I hace a set of 13", I believe Super 44's, I was going to install. But, if I will have the drone, I will look onward.
Old Apr 1, 2009 | 05:44 PM
c4cruiser's Avatar
c4cruiser
Most of the Corvette accessory catalogs sell a Flowmaster muffler that is a direct fit for C-4's, but I think they are nothing more than a 40 series with dual outlets and the 75 degree bent inlet pipe.
Super 44's are supposed to be louder than the 40 Series. Any Flowmaster I have ever heard on a C4 has been horrible for interior resonance. A friend had a pair of 40's on his 90 with headers, no cats and true duals, and you could hear him a mile away. There was no way to drive the car on trips.
You might want to look at Magaflows or Walker Super Turbos. Also, Flowmasters actually don't flow as well as some other performance mufflers.
Old Apr 1, 2009 | 06:45 PM
Vintagevetter's Avatar
Vintagevetter
Amen on Flowmaster's resonance I had a set of 40's on my 94 coupe when I bought it. The "Dronemasters" set up one hell of a resonance right in the cruise zone. 1800 to 2100 RPM in 6th gear A real PITA on long trips on the Interstates.
Old Apr 1, 2009 | 06:49 PM
BAM92's Avatar
BAM92
I have them and I think they are 50's, definelty not 40's.
Old Apr 1, 2009 | 07:20 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I have a set of Flowmaster 50's and I do not have any resonance.
Old Apr 1, 2009 | 08:04 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I have 40s with true duals no cats. I am laying down dynamat extreme then another insulator over that. I think that should help some. It sounds badass from outside the car regardless.
Old Apr 1, 2009 | 10:20 PM
Midnight LT4's Avatar
Midnight LT4
I have the flowmaster cat back on my car and its super quiet with the windows up. Pretty close to stock sounding. I almost considered removing the resonator. I like it now, its loud enough to be noticed and quiet enough to never be too loud. No problem with resonance.
Old Apr 1, 2009 | 10:42 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
50 series. Direct replacement for stock cat-back. No resonance and still sounds powerful @ idle for people who know nothing about a stock L98.
Old Apr 1, 2009 | 10:53 PM
Demonic85's Avatar
Demonic85
I went with Magnaflow over the Flowmaster since they're made out of SS, flow better, and have a rumble that reminds me of LS1 cars. I had flowmasters on several other vehicles in the past and it had the resonation problem on those as well.
Old Apr 1, 2009 | 11:43 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I have 3.73 gears in my 93, w/LT headers, and Flowmaster cat back and no cats. No drone, but my rpms are always higher, especially with 2800 rpm stall.
Old Apr 2, 2009 | 05:03 AM
Weav's Vet's Avatar
Weav's Vet
Get the 50 Series. No drone.
Old Apr 2, 2009 | 09:37 AM
TA's Avatar
TA
I'd say if you're concerned about resonance and really want Flowmasters then go with the 50 series. Anything else and you'll likely have some annoying drone. I have LT headers, no cats, and 40 series Flows with a x-pipe on my car and the drone will rattle the fillings out of your teeth
Old Apr 2, 2009 | 11:28 AM
NEVRL8T's Avatar
NEVRL8T
Old Apr 2, 2009 | 12:23 PM
LT4POWR's Avatar
LT4POWR
I had some "corvette specific" ones several years ago. They had some drone (LTs, no cats), but sounded great!
Old Apr 2, 2009 | 01:31 PM
breathial's Avatar
breathial
I'm going to go with Turbos on mine. No resonance, and have the "old skool" sound.
Old Apr 2, 2009 | 04:49 PM
Master__Shake_'s Avatar
Master__Shake_
50s are one of the quietest mufflers in flowmaster's line, producing about 1/2 of the noise level a 40 series would. Not saying WOT is quiet, by any means, but the noise level at cruise and idle is significantly reduced both inside and out of the car. I have super 44s and, the way I have them set up, there is almost no drone - but it is LOUD cruising anywhere above 2600 RPM. At 2k or under though, it is very tolerable.
Old Apr 3, 2009 | 04:31 PM
M.J.L.'s Avatar
M.J.L.
[QUOTE=c4cruiser;1569535383]Most of the Corvette accessory catalogs sell a Flowmaster muffler that is a direct fit for C-4's, but I think they are nothing more than a 40 series with dual outlets and the 75 degree bent inlet pipe.
Super 44's are supposed to be louder than the 40 Series. Any Flowmaster I have ever heard on a C4 has been horrible for interior resonance. A friend had a pair of 40's on his 90 with headers, no cats and true duals, and you could hear him a mile away. There was no way to drive the car on tripsQUOTE]
If I get headers,I will have the exact same set up. If it is as loud as you say it is, my car will sound like its got 500+ hp.
To Flowmaster muffleer question
Old Apr 3, 2009 | 04:55 PM
Master__Shake_
It all depends how far the tips are out and how big the pipes are. If you keep the pipes around 2.5" and the tips are further than 2" from the bumper, there won't be enough room for the exhaust to reverberate on the car. I'll have to take a vid of my car on a cruise to show you guys, but there's almost no drone under 2k like the muffler eliminators had.
Old Apr 3, 2009 | 05:40 PM
lltrevino's Avatar
lltrevino
Exact same set up, I have to install on the Vette, with 2.5" tubing. For once, Idont want to hear the dredded drone, I guess I am getting older. I use to just turn up the stereo, but I am getting hearing loss by now.
Old Apr 3, 2009 | 08:59 PM
TA's Avatar
TA
Sounds great in theory, but I can tell you the tip placement on my car had zero effect on the resonance. I've had my tips flush with the bumper cut-outs and I've had them sticking out 2.5" (at least) and the annoying, teeth rattling, drone was the same either way.
