electric WP relay failures
Old Apr 2, 2009 | 08:10 AM
kwd1's Avatar
kwd1
Default electric WP relay failures
Hi all,
I've been running an electric WP for about the last 4 years/2000 miles. In that time I've had 4 relays go bad on me. I was using autozone high current relays. Switched to the relay from Ecklers:
http://www.ecklers.com/product.asp?p...6&dept_id=1126
The relay is labeled as rated to 40 amps. This last one went bad after 1 year/200 miles.
Any ideas why a relay would continually fail like this? Could the pump be drawing too much current? The last time it failed, the pump was not running and the relay was warm.
thanks
Ken
PS man I need to drive this car more....
Old Apr 2, 2009 | 08:56 AM
dizwiz24's Avatar
dizwiz24
This is exactly why I never did the electric water pump mod.
Despite a proven power gain, I never ' trusted' it in terms of reliability.
Someone had posted about a relay failure (no problems with the pump, just the relay) and ended up overheating. They warped their heads.
I think Nathan Plemons hooked his up in a such a way that his dash lights would go out if the relay failed.
I cant answer why the relay failed.
I can conly tell you that back 8 years ago, when I was considering it, people were using 'Barry Grant Relays'
or something like that.
Im not 100% sure of the name, but the company name was someones name.
Old Apr 2, 2009 | 09:17 AM
kwd1's Avatar
kwd1
I may have figured it out. I cracked open the old relay and found the inside was rusted and corroded! Reason for this was I had mounted the relay with the terminals pointing up! I did this just because thats the way it fit best. But if you notice, all the stock relays are mounted with the terminals down!! Makes sense, water must have gotten on the terminal block and seeped through.
I'm in a WP thread a few years ago where someone had posted a wiring diagram for a buzzer if the WP was not running.
Old Apr 2, 2009 | 10:50 AM
anesthes's Avatar
anesthes
Never really understood electric waterpump.
Alt is belt driven. So while saving the load of the waterpump your adding to the load on the alt.
-- Joe
Old Apr 2, 2009 | 01:35 PM
bjankuski's Avatar
bjankuski
-- Joe
That is true but at high RPM the mechanical water pump puts alot more load on the engine then the electric water pump. That is where you save your power.
Old Apr 2, 2009 | 01:41 PM
tachout's Avatar
tachout
In the build I am doing I am going to be doing an electric water pump drive. I am going to replace the motor with something with just a little more umpf, and want to run the water pump and alt as well. My only thought in doing so is I could run the electic water pump after running it hard, and help cool the engine, while still charging the battery. I am wanting to also put an electric oil pump in. This will not be for engine oiling, but instead for the oiling for the twin turbos to help them cool down after running hard. Not sure if it will work, but still looking into it. Got to keep the relays in mind, and am going to put in a trouble light, as well as, a buzzer so I know if something goes wrong. Thanks for the added ideas to this circuit.
Old Apr 2, 2009 | 03:17 PM
blue94's Avatar
blue94
Running a Meziere HD pump with the WIK346 relay kit two years without an issue.
Old Apr 3, 2009 | 04:26 PM
adamc's Avatar
adamc
Default stero shop
I went to the stereo shop and purchased some good relays from them. I have been very happy with the EWP mod.
Old Apr 3, 2009 | 05:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You need either a weather pack relay, or pack them up good to keep the water out.
To electric WP relay failures
