Frisbee Removal
Old Apr 2, 2009 | 03:19 PM
gmc's88vette's Avatar
gmc's88vette
Default Frisbee Removal
I read on C-4 tech info and FAQ that the frisbee should be removed because it robs h.p. Also said it was there to help belt. If the frisbee is removed do I risk problems with the belt? I would appreciate your input.
Old Apr 2, 2009 | 03:24 PM
bill mcdonald's Avatar
bill mcdonald
if my memory is correct, I think it is there to balace vibrations when the AC is on.
I removed mine a long time ago. never noticed a thing.
Old Apr 2, 2009 | 03:30 PM
engle1147's Avatar
engle1147
You don't need the frisbee you can chuck it....http://forums.corvetteforum.com/c4-p...e-frisbee.html
Old Apr 2, 2009 | 04:47 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Put the bolts back in with a lock washer after removal.
Old Apr 2, 2009 | 05:43 PM
WW7's Avatar
WW7
Or if its like my 89 is, you have to use 2 washers and a lock washer on each of the 4 studs before you put the nut back on, if you don't it won't pull up tight. I have seen another 89 vette that had the same setup as Badduck, it seems GM used which ever one they had at the time...WW
Old Apr 2, 2009 | 07:31 PM
gmc's88vette
I have bolts also. Thanks for the input. I was wondering if I should put them back. Frisbee is history!
Old Apr 2, 2009 | 07:58 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I removed it 10 years ago, and never had any problems, with A/C on or off, and HP never felt differences.
To Frisbee Removal
