1995 6-speed shift knob
Old Apr 2, 2009 | 09:06 PM
pitchadude's Avatar
pitchadude
Default 1995 6-speed shift ****
How do you remove the **** in order to change the boot? The stem going into the **** itself is burred where the previous owner tried to remove the ****. Thanks in advance.
Old Apr 2, 2009 | 09:25 PM
STL94LT1's Avatar
STL94LT1
I hooked a Vicegrip on mine and tapped it out with a hammer.
Old Apr 2, 2009 | 09:35 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Remove the cap then you should be able to remove the plug with vicegrips or a screwdriver.
Old Apr 3, 2009 | 12:20 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I used a drum brake adjuster tool. It looks like a small crowbar. It was just the right size to dig under the wedge and get it out.
Old Apr 3, 2009 | 09:39 AM
pitchadude's Avatar
pitchadude
Thanks for the ideas.
Old Apr 3, 2009 | 11:33 AM
StealthLT4's Avatar
StealthLT4
I used a combination of 4 metric tonnes of PB-Blaster, 3 pairs of Vice-Grips, a flat-blade screwdriver, and eventually a paint can top-opener to pry it out
Old Apr 3, 2009 | 12:13 PM
pitchadude's Avatar
pitchadude
Default brake tool
The brake tool did the trick. I went from the side and it slid right out....easy! That was good information. Stealth LT4, that was funny stuff.
To 1995 6-speed shift knob
