does a 1990 have addition a/c braces????
Old Apr 3, 2009 | 05:45 PM
jeffp1167's Avatar
jeffp1167
Default does a 1990 have addition a/c braces????
I'm curious, does a 1990 have additional braces going to the a/c bracket from the exhaust manifolds? If they do can someone post a detailed picture of them? Also does the alternator & smog pump have4 anything like this?
I want to get my a/c going again but not sure if the car ever had these types of braces.
Old Apr 3, 2009 | 06:37 PM
rodj's Avatar
rodj
Outside rear of compressor to exh stud above # 4 plug
A/c bracket (Hole behind idler ) to stud on fuel pump block of plate
Alt has brace back to exh stud above #1 plug
AIR pump has brace back to boss on intake next to thermo housing
Old Apr 4, 2009 | 09:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, if the exhaust manifold has a stud instead of a bolt in that position then the round bracket (with flattened ends) is missing.
Old Apr 4, 2009 | 09:36 AM
jeffp1167's Avatar
jeffp1167
Mine has none of this! can either of you get a good picture of these braces for me?????
Old Apr 4, 2009 | 09:43 AM
rodj's Avatar
rodj
Pic sent
Old Apr 5, 2009 | 05:54 AM
Yorcci's Avatar
Yorcci
Here you can see the stock alternator brace connecting to the back of the alt. (the bigger alt. is CS-144, which I installed):
And later I had the brace modified to fit with the CS-144 alt, because the attachement is different, but this pic is a bit clearer than the one above:
Old Apr 5, 2009 | 11:07 AM
jeffp1167's Avatar
jeffp1167
thanks yorcci & rodj ....... seems my car is missing all of them, if I can't find the originals I will probably have to fabricate some. yet another setback LOL. Maybe I can buy some from other GM makes and modify them to work or something.
To does a 1990 have addition a/c braces????
