Replacing torx bolts on intake manifold side
Old Apr 5, 2009 | 05:14 AM
IslandVette808's Avatar
IslandVette808
Default Replacing torx bolts on intake manifold side
I know people have done this before and have seen pics of different bolts rather than the torx bolts on the intake side, but for some reason I can't find much info on it using search. So for those that have done this, which head pattern did you go with or would recommend when replacing the troublesome torx? Did you guys use washers with them? What is the pitch, length, size of the bolts that you have used? Did you guys get them online or at your local Home Depot or Lowes? I plan on repainting the plenum, runners and valve covers so this would be a good time to replace them when I get them off. Thanks.
