Would This Exhaust Setup Work???
Old Apr 6, 2009 | 07:46 PM
MetsC6Z06's Avatar
MetsC6Z06
Default Would This Exhaust Setup Work???
I wanted to get a B&B catback exhaust i decided to save some money.
I want to get Exotic Muscle 1 3/4 longtube headers and header extensions with cats.
And i want to hook it up to this corvette central exhaust. It will be al ot cheaper and i think i would should see some good hp gains from it.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Will this setup work?
Met
Old Apr 6, 2009 | 09:15 PM
MetsC6Z06's Avatar
MetsC6Z06
Default anybody?
Old Apr 6, 2009 | 09:37 PM
ultraviolet70's Avatar
ultraviolet70
You can make almost any exhaust work with a little fab work. The downside I see to this is your removing S.S. exhaust to install aluminized, it'll save you some $ but IMO I wouldn't do it.
Old Apr 6, 2009 | 10:01 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Get the headers on then take it to a shop and tell them what you want.
Old Apr 7, 2009 | 04:01 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You just cannot beat a SS system for durability.
But, if $$ are really tight now, the system should work fine till it corrodes away.
Be sure those are hi-flow cats. The "system" should flow at least 660cfm if behind a 300chp motor.
Old Apr 7, 2009 | 05:43 AM
pologreen1's Avatar
pologreen1
I have the 2 part SS duals, and IMO your best bet is to, get your headers and extensions and cats (if you have to have them) and then go to a shop and have them finish it with some pipes to the mufflers.
the kit you have posted is a whole set up from block back, you won't need that becasue your headers and extensions and stuff will be over half the length already.
Old Apr 7, 2009 | 08:15 AM
Demonic85's Avatar
Demonic85
thats what I did and it turned out to be the cheapest way to go as well. Driving on headers alone is.... well just say VERY LOUD
To Would This Exhaust Setup Work???
