Cam and tune
I will be shifting at 5800 tops and a redline of 6000.
As it sits now its a 383 10.2:1 stroker TPI 58mm TB and Dart heads.
1.6rr 30lb injectors and adjustable fuel pressure regulator.
STOCK TUNE
I will be buying LT headers with 2.5 inch pipes all the way with magna bullet cats to mufflers.
700r4 has a shift kit and 3.08 final gear.
I will also be getting a Holley stealth ram by august so breathing will be no problem.
They have a .300/.300 or close grind cam.
I dont want to go to radical since this is my daily driver just some more topend as I have stock cam.
and I have a 2200 TC
I will be getting a chip at the same time to accomidate the new cam and lifter design
