mass air flow sensor code
Old Apr 7, 2009 | 07:23 PM
stinger54's Avatar
stinger54
Cruising
Default mass air flow sensor code
I have a 87 corvette and no matter what i do i can not stop the mass air flow sensor code from coming up. The car runs great until that darn check engine light comes on and then it seems to bogg way down. The light does not stay on, it may be on when i start the car it may not be on, it comes on at times when i am just driving. If anyone else has had this problem please help. Thanks
Old Apr 7, 2009 | 08:16 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you have replaced the two MAF relays and the MAF and the problem persists then it's either in the cables (or connectors) or in the ECM.
Old Apr 7, 2009 | 08:50 PM
stinger54's Avatar
stinger54
Cruising
i am a 54 year old woman and i am not sure what you are talking about. Is the MAF relays behind the battery and called burn off relays? I have replaced the ECM. I was told that I needed a factory orginial parts mass air flow sensor and I paid 350.00 for one from Ecklers and it seemed to work for about a week and then went back to its little fits.
Old Apr 7, 2009 | 09:04 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Maf
Un plug MAF and see if it runs better. I do this first when doing MAF related stuff. If im having a MAF issue, unplugging will help me diagnos the problem. Good Luck
Corvette Mike
Old Apr 7, 2009 | 09:22 PM
stinger54's Avatar
stinger54
Cruising
Mike, My car will not even pull out until the temp. reachs operating temp, when I start to let the clutch out, I have the 4-3 the car just dies and it doesnt matter how high I reeve it, the poor thing dies until it warms up then it will go. I have unplugged the MAF and it seems to do a little better but not alot.
To mass air flow sensor code
