info panel
Old Apr 7, 2009 | 07:35 PM
L98vette08's Avatar
L98vette08
Cruising
Default info panel
i have an 89 vette and on the dash where you switch between fuel MPG/instant rate my reading stay at 99mpg and 10 instant? now it would be nice at 99 mpg but we all know that it is wrong..haha just woundering if there is an easy fix or something major.i also tried to reset and went back to doing the same thing.
Old Apr 7, 2009 | 08:52 PM
engle1147's Avatar
engle1147
The "math" is done by the ECM. Does the speedo work? If your getting some type of reading then you may have a connection problem before, in, or after the cluster or an ECM problem.
Old Apr 7, 2009 | 08:55 PM
L98vette08's Avatar
L98vette08
Cruising
yeah the speedo works. thanks for the info i wasnt sure how it actually worked
Old Apr 7, 2009 | 09:01 PM
engle1147's Avatar
engle1147
You can try to reseat the connectors on the ECM & instrument cluster to see if that helps. Got any other cluster/ECM related problems that might help to narrow it down further?
Old Apr 8, 2009 | 09:15 AM
L98vette08's Avatar
L98vette08
Cruising
no not that i know of there isnt any problems
To info panel
