does cat size matter??
Old Apr 8, 2009 | 05:04 AM
Qiken's Avatar
Qiken
Default does cat size matter??
Deciding to replace the original cat in my 89 with an aftermarket,do they all serve the same purpose regardless of their size ,as even the aftemarket offerings seem to vary greatly in design....
In other words does size really matter
Old Apr 8, 2009 | 07:24 AM
frenchyoliver's Avatar
frenchyoliver
It does matter depending on main or pre cats ?
Old Apr 8, 2009 | 08:44 AM
WW7's Avatar
WW7
Some of the aftermarket cats say they flow 23% better, I would go with a name brand with the higher flow.These can be had for around $150.00 to $180.00 .WW
Old Apr 8, 2009 | 08:53 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I put on a high flow Magnaflow (Carsound) main cat. The size that matters is inlet/outlet size. Got mine on eBay for $65.00. It is the universal model.
Old Apr 8, 2009 | 09:27 AM
jeffp1167's Avatar
jeffp1167
do most of these aftermarket "direct fit" cats have the special air injection pipe that has the correct flare fitting so it matches the stock pipe?
Old Apr 8, 2009 | 10:09 AM
BADDUCK's Avatar
BADDUCK
You can get them with or without the air tube. I can't speak for all on fit.
My fitting fit the Magnaflow tube.
Old Apr 8, 2009 | 05:43 PM
Qiken's Avatar
Qiken
Main cat no precats
Old Apr 8, 2009 | 05:48 PM
pologreen1's Avatar
pologreen1
a real cat or a (test cat)?
meaning straight tube.
I think it matters very much it can be a restriction.
Old Apr 9, 2009 | 07:02 AM
Qiken's Avatar
Qiken
Real Cat,I was going to gut the existing Original cat and weld a tube in however im a bit concerned this may increase resonance?as my current system already has had me found guilty by the noise police
To does cat size matter??
