Priming new ltx engine
Old Apr 8, 2009 | 11:51 PM
chadihrig121's Avatar
chadihrig121
Default Priming new ltx engine
Whats the best way to prime the new lt?
with a primer tool on the engine stand? or should i just turn it over with no plugs till the gauge reads...
Old Apr 9, 2009 | 09:39 AM
Elephanthead's Avatar
Elephanthead
Personally I think on the engine stand is a little more conservative method, but if it is properly pre lubed and the oil pump is pack with prelube, I think you can get away with either method. Is there any reason not to prime it on the engine stand?
Old Apr 9, 2009 | 05:29 PM
RichS's Avatar
RichS
If the intake is off use a drill and preoiler to prime. I allways do this before the intake goes on. Otherwise you have to crank it till you see pressure.
To Priming new ltx engine
