Lt1 advice needed for replaceing opti spark
Old Apr 8, 2009 | 03:26 PM
RONJON851's Avatar
RONJON851
Default Lt1 advice needed for replaceing opti spark
Hey how could i pull the crankshaft balancer without raiseing the engine so i could install the opti spark?ir if i nees to raise the engine how do i access the engine mount bolts?
Old Apr 8, 2009 | 03:30 PM
myc4vette's Avatar
myc4vette
Didn't have to raise the engine on my 92.
2VettesMike's Avatar
2VettesMike
Do you mean the crankshaft hub? I think the pulley/balancer will unbolt from the hub if I remember by repair correctly.
The only way I could get the hub off was with the special GM tool. It is expensive, you may be able to rent one from someone. Very tight quarters to the crossmember.
If you are interested in the tool and articles on it try:
This is the GM puller that I used. It is made by Kent-Moore pn J-39046
I bought it from:
http://www.etoolcart.com/index.asp?P...OD&ProdID=7181
There is an example of it in use at this web page:
http://www.karl-ellwein.org/lt1350y2k2.htm
Old Apr 8, 2009 | 04:38 PM
toptechx6's Avatar
toptechx6
The balancer must be removed but it is separate from the hub which does not need to come off. The balancer is held on with 3 bolts plus "rust"
After removing the bolts take a 2"X4" and a BFH, from underneath the car slide the lumber over the front crossmember to contact the back side of the balancer then swat the other end with the BFH, rotate the crank and repeat until the balancer comes off the hub. The engine does not need to be raised.
Old Apr 9, 2009 | 11:11 AM
NEVRL8T's Avatar
NEVRL8T
But be careful and only whack the balancer and not the hub itself. Its a two piece unit and you will damage the hub if you don't hit it on the outer edge.
Old Apr 9, 2009 | 11:30 AM
MikeC4's Avatar
MikeC4
...place the piece of wood on the inner part of the balancer/pully. A 2X4 is too large though, use something like a 1X2. You need to turn the crank after 2 or 3 whacks so the balancer/pully comes off evenly. I think the center hub bolt is 5/8" and use a long breaker bar to easily turn. Best position is to lie right behind the front wheel. Looking towards front of engine, you will see part of the balancer/pully. The piece of wood needs to be about 3 or 4 feet long to reach. Get a sturdy piece of wood like pressure treated deck wood. Balsa wood will not work !
3 bolts hold the balancer/pully to hub. No need to raise engine or do anything outrageous for this procedure. It is easy....you just have to do it one time to see how easy it really is....
Old Apr 9, 2009 | 11:44 AM
RONJON851's Avatar
RONJON851
Thanks,this is the help i really appreciate,and so far i've tried all of this and should soon have it off.thanks again everyone for your quick responses!!!!!!!!!!
Old Apr 9, 2009 | 11:45 AM
RONJON851's Avatar
RONJON851
THANKS EVERYONE FOR THIER QUICK RESPONSES AS IT IS VERY HELPFUL AT THIS POINT IN THE PROCESS.
Old Apr 9, 2009 | 11:51 AM
corvette-pilot's Avatar
corvette-pilot
I used a tie rod splitter from the top and was able to get mine off. Just hit it a couple of times then switch sides to rock it off. Seems a lot easier than trying to get underneath the car and swing a hammer.
Old Apr 9, 2009 | 05:30 PM
adamc's Avatar
adamc
Default wedge
I wedged a tall socket under one of the trhee hub bolts and the other end of the socket against the crossmember. This kept the hub from turning while I loosened the other bolts. Maybe not the best way, but it worked for me in that tight space and no special tools purchased or used.
To Lt1 advice needed for replaceing opti spark
