belt tensioner
Old Apr 10, 2009 | 01:42 AM
Whitecloud's Avatar
Whitecloud
Default belt tensioner
After I have released the tensioner and put the belt back on do I have to retighten anything? Or will it tighten back up once the engine is running? This is on an 87.
Old Apr 10, 2009 | 02:25 AM
rodj's Avatar
rodj
Tensioner should return belt to tight position, no other adjustments needed
Old Apr 10, 2009 | 11:31 PM
Whitecloud's Avatar
Whitecloud
Thanks, I was hoping that was the case.
Old Apr 11, 2009 | 07:48 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You should have had to put the belt back on and THEN release the tensioner...
Old Apr 11, 2009 | 09:11 AM
383vett's Avatar
383vett
It should be tight before starting.
To belt tensioner
