Temp Gauge Transmission
Does the top cooler line go to, or return from the Trans cooler?
Any thoughts on what size Trans Cooler needed if I don't run Fluid through the Radiator?
Joe
Since the rebuild I have the sensor in the case, drivers side. One of the ports there.
Even the largest cooler is going to have trouble cooling with no airflow. I've found without the radiator it only runs 2-3° cooler but spikes real hot in a traffic jam. Use a fan!
Gauge in car:
It just has a plug threaded into it.
You can use that location as it has the correct thread pitch for the temp sender.
btw, nice interior Andrew. Love the black widow colors.
My temp sensor is 3/8 pipe thread I will check it out.
I was thinking of using my Engine oil Temp gauge for the trans or maybe even installing a 2 way toggle switch to go between trans and Engine oil temp.
Joe
As stated above I was going to use a 3/8" pipe Engine oil Temp Sender I wonder if the smaller one would work on the Factory Oil Temp Gauge?
Joe
