It is behind the dash pad on the passanger side of the car. You get at it from the bottom. Remove the black plastic underside dash cover and it is bolted up in place behind the dash pad. Two 10mm bolts hold it in place.
I've traded out my ECM and that wasn't the issue with my code 41. None of the ECM's come with PROM's and I've already got a hypertech prom in the ECM I have now.
I suspect it's the problem but I'd rather put back in and OEM PROM.
Can't help with a 1986 PROM, but I can offer this..
A code 41 is pretty simple, and specific. If a replacement ECM didn't cure it the problem about Has to be a faulty ground or open circuit for the ECM cylinder select (pin D3 on an '85 and I Think it's the same for the '86 - only a few of the pins change). Nothing else to it.
The only other even Remote possibility would be something wrong with the pickup coil, providing a goofy number of reference pulses to the ECM - but That would be causing other things to go haywire as well, a code 41 would be the Least of your problems.
Hmmm - there IS a setting in the PROM program for "number of cylinders", which I suppose Could be messed up in your Hypertec chip. I'd say Unlikely, but possible. If so that Could explain the code 41, but it would have had to have Been like that right along - since the chip was brand new. I don't think I've ever seen a PROM chip "die", or loose memory or something like that.
