front brake pads
Old Apr 11, 2009 | 01:17 PM
jameskarate's Avatar
jameskarate
Default front brake pads
I'm replacing my front brake pads and am wondering is there anything that I should be made aware of that might make this job difficult.
Old Apr 11, 2009 | 01:40 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You didn't say which year car which type of brakes. Buy new pins.
Old Apr 11, 2009 | 01:50 PM
GKK's Avatar
GKK
Just, remove the caliper and old pads compress the piston back in the caliper and reinstall the new pads. One thing that'll really make a big difference is to buy the Earl's Solo Bleed screws which are only $20 for four of them at Summit. You'll want to bleed the old brake fluid out if it's black.
With the Earl Solo Bleeds in place on each caliper, bleeding each brake caliper is SOOOOOOOOOOOOOOOOO easy! Don't buy the "Russel" or "Speed Bleeder" brand bleeders which uses sealant goo on the threads.
Old Apr 11, 2009 | 02:49 PM
jameskarate
sorry 88 vette also what size bolt holds caliper on
Old Apr 11, 2009 | 05:44 PM
GKK's Avatar
GKK
No bolts to remove. The caliper is held to the bracket with a retaining pin and circlip.
Just, remove the lower circlip and pull out the retaining pin with some pliers. The caliper will lift right out.
Old Apr 12, 2009 | 12:47 PM
65747785's Avatar
65747785
Hahahaha, are we confusing calipers with brake pads? I think you are.
Old Apr 12, 2009 | 01:49 PM
jimg's'93's Avatar
jimg's'93
The calipers have to be removed to replace the pads/linings and yes, this is simply a circlip and retaining pin. I'd keep something handy to lay the caliper on while it's removed to avoid putting stress on the hose. You can even use a bent metal coat hanger to 'hang' the caliper while replacing the pads.
Old Apr 13, 2009 | 08:31 AM
65747785's Avatar
65747785
On my Corvette's the calipers are mounted to their brackets with 2 bolts. Including my 85. James asked, what size are the bolts. Obviously he doesn't have clips on his calipers.
Old Apr 13, 2009 | 10:55 AM
GKK's Avatar
GKK
88-96 C4 Vette's don't use the caliper Slider Bolts that are used on the earlier C4 Vettes.
His 88 has the retaining pin and circlip.
Old Apr 13, 2009 | 11:09 AM
65747785's Avatar
65747785
Okay, I should have remembered that. I wasn't sure what year the calipers changed, I forgot. Odd though that he asked what size bolt. Maybe he was looking at the bracket bolts???
Old Apr 13, 2009 | 05:06 PM
jimg's'93's Avatar
jimg's'93
Or he hadn't looked at the calipers yet. Sounded like it.
To front brake pads
