Rattle and Hum
Old Apr 11, 2009 | 08:17 PM
blacker's Avatar
blacker
Default Rattle and Hum
My 1989 six speed coupe with 72,000 miles recently had the catalytic converter removed and replaced with a hollowed out stock cat in its place. The reason for this was that the cat was completely blocked. Since then it has run very well, however, I have developed a new problem. After I have driven to a destination, parked the car and have restarted it after an hour or so, there is a discernable rattle or knock coming from the engine or underneath the car. I get a "check engine" light but only briefly. It comes and goes. If I engage the clutch the knock goes away but not completely. The sound may be coming from the connection from the y-pipe to the cat or from the pre-cats. If it sits for a day or so and I drive it again there is no noise. It only happens if and only if I have driven it, stopped and started it again.
Old Apr 11, 2009 | 09:23 PM
engle1147's Avatar
engle1147
Did they check the pre cats too? I bet the pre Cats are damaged also and are now throwing chunks/pieces of pre cat at the new down stream converter.
Old Apr 12, 2009 | 11:24 PM
blacker's Avatar
blacker
That's my guess. I just hope it isn't something worse.
To Rattle and Hum
