another cracked brake booster!
Old Apr 12, 2009 | 03:00 PM
motodog's Avatar
motodog
Default another cracked brake booster!
i have replaced at least 5 brake boosters in this car, any reason why?
Old Apr 12, 2009 | 03:02 PM
Demonic85's Avatar
Demonic85
What kind of replacements have you been using?
Old Apr 12, 2009 | 03:19 PM
runner140*'s Avatar
runner140*
Quality of replacement? I'm on my origional at over 160,000 miles.
Think about getting a tin one.
Old Apr 12, 2009 | 03:22 PM
Demonic85's Avatar
Demonic85
my original is failing at 120K, not sure if i'll get around to replacing it anytime soon though.
Old Apr 12, 2009 | 03:26 PM
JackDidley's Avatar
JackDidley
If you are running uncoated headers, the heat will kill the plastic. A lot of guys use a metal aftermarket booster.
Old Apr 12, 2009 | 03:29 PM
motodog's Avatar
motodog
no headers, its an autozone. that much of a dif on that thing
Old Apr 13, 2009 | 12:31 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I have had an autozone for 4 yrs w/no trouble, is it cracking in the same spot?
You might have a missing heatshield.
Old Apr 13, 2009 | 02:30 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Don't lean on your master cylinder either. (Common sense but sometimes may be uncommon.)
Old Apr 13, 2009 | 06:15 PM
pologreen1's Avatar
pologreen1
dang that sucks
Old Apr 14, 2009 | 12:31 AM
Curveit's Avatar
Curveit
I was told...if your Master Cylinder is leaking Brake Fluid from the Rear Seal; behind the mount, it can enter the Booster and that causes it to crack. I just recently did both on my '86... Booster first, as it had cracked.
Old Apr 14, 2009 | 11:19 AM
65747785's Avatar
65747785
That's weird I never heard or read in books this happening. Some people switch to the metal ones as mentioned about.
We're all curious, where are they cracking? And how long does it take before they crack? There has to be a logical answer to this. What's AutoZone have to say about this?
Old Apr 14, 2009 | 03:24 PM
Lichen's Avatar
Lichen
Autozone sells the crappy Cardone brand. I went through 2 in a year. Do yourself a favor, spend an extra $100 and order a PBR through Ecklers.
Old Apr 14, 2009 | 05:44 PM
Targa86's Avatar
Targa86
Very common. I had the same problem, heat is the culprit. Either put some epoxy over the crack and deal with the eyesore or get an aftermarket metal booster(not much more $ than the plastic one).
Old Apr 14, 2009 | 09:36 PM
vader86's Avatar
vader86
Heat is the reason why.
You should go to a metal booster.
Old Apr 15, 2009 | 03:50 AM
LT4 F45's Avatar
LT4 F45
i did fix a crack on my replacement booster on my 87 with some epoxy stuff painted in black and it works ... try it before another replacement!!!
To another cracked brake booster!
