Stuck Oil Filter
Old Apr 12, 2009 | 03:31 PM
Big Craig's Avatar
Big Craig
Default Stuck Oil Filter
After getting the car out of storage, I decided to spend the day yesterday getting my 91 ready for the season. Drained the oil, no problem, but the filter (ac454) wouldnt budge.
Tried a cap wrench, tried a strap wrench, but that started crushing the filter. Tried tapping with a hammer/screwdriver but no use. Couldn't get a toothed wrench around it because of the clearance.
Finally tried the big screwdriver through the filter trick, but that wound up just bending the filter and making a big hole in the filter as I turned it.
Any other tricks??? ... The clearance is terrible with the shorter filter. I'm so disgusted that I can't get this loose and I really hate to pay to have it flat bedded to the shop for this.
Thanx in advance...
Old Apr 12, 2009 | 05:04 PM
pologreen1's Avatar
pologreen1
spray something on it a couple of times a day for a day, it will come off, then make sure you only hand tighten it next time, and pre oil the seal.
good luck.
don't mess too much with it any more until penatrated or you will have a bigger mess with less mass to work with.
Old Apr 12, 2009 | 05:42 PM
Joe C's Avatar
Joe C
Originally Posted by pologreen1
...and pre oil the seal.
- you just cant believe how important that is - back in 1989, i had a 69 coupe, and went to change the oil shortly after i bought the car. well from the door jam sticker, it indicated it was recently changed at some quick lube place. i went thru the same thing - couldn't get the filter off. after several hours, and destroying the filter it came off. i noted the seal was bone dry. what i had to do to get the damn thing off was to completely rip off the filter case and get down to the screw on mounting plate. then, i stuck two 1/4 inch (i think) bolts into the drain holes (opposite ends) and using a pry bar, or maybe a wrench as a lever, slowly worked the thing loose enough to get it to unscrew. gawd, i hate those $8/hour quick lube monkees. don't know it thats the OP problem, but that's what i had to do...
good luck...
Old Apr 12, 2009 | 05:50 PM
StealthLT4's Avatar
StealthLT4
If you've tried the screwdriver trick and it just mangled the filter, you're pretty much relegated yourself to the one course of action left; basically, tear the filter apart and get to the mounting plate, and use either some bolts and a pry bar or some vice-grips to grab what you can near the base where it won't tear, and get it off like that.
I don't think I've ever NOT had an issue getting the filter off of a car that I didn't do the last oil change on... ugh.
Old Apr 12, 2009 | 11:15 PM
Big Craig's Avatar
Big Craig
Wasn't done at a quick lube place, but was definitely somebody I trust with the car.
I'll hit it with some PB Blaster tomorrow a few times, then push it back up on the ramps and see what I can do. The real problem there is the clearance SUCKS. Getting any kind of leverage is a bear.
Old Apr 13, 2009 | 12:12 AM
pletzvet's Avatar
pletzvet
Channel lock makes a good oil filter wrench that might work. I don't have one myself but thought if I ever got into the situation you are describing it might be the solution.
http://www.channellock.com/acb/store...&Category_ID=5
Old Apr 13, 2009 | 01:07 AM
Big Craig's Avatar
Big Craig
Tried one of these, but due to clearance, I could only get it around the bottom of the filter ... tore it up good. Boo.
Old Apr 13, 2009 | 08:12 AM
Churchkey's Avatar
Churchkey
This is the style oil filter wrench you need it can be positioned all the way up to the top of the filter. They are available for different filter diameters.
http://www.thetoolwarehouse.net/shop/KD-2029.html
Old Apr 13, 2009 | 08:18 AM
runner140*'s Avatar
runner140*
Great tool....I've got one but the problem is clearance isn't there to use that tool. At this stage, he's going to have to take it apart, piece by piece.
Old Apr 13, 2009 | 10:49 AM
my83432's Avatar
my83432
Have you tryed something like this. http://www.sears.com/shc/s/p_10153_1...ord=oil+filter
I had a two legged one that I used changing oil at Firestone and it worked very good.
Old Apr 13, 2009 | 10:56 AM
Big Craig's Avatar
Big Craig
Actually, my neighbor loaned me something like this, and I mangled up the filter beyond all recognition.
I did some PB Blaster, and still no dice this morning.
I have too much work piled up this week to keep playing ... just going to suck it up, and let the guys at the shop have at it.
Thanx for all the good suggestions.
C...
Old Apr 13, 2009 | 11:50 AM
Demonic85's Avatar
Demonic85
If I cant get a stuck oil filter off with the wrench I usually jam a screwdriver into the side and twist, works everytime
Old Apr 13, 2009 | 01:56 PM
NEVRL8T's Avatar
NEVRL8T
Old Apr 13, 2009 | 02:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Originally Posted by TheAngelOfDeath
I've never had one that an oil filter removal tool couldn't coax off. You can get them at auto parts stores like NAPA, AutoZone, Carquest, etc...
To Stuck Oil Filter
