Retard stock cam?
Old Apr 13, 2009 | 09:20 PM
Aardwolf's Avatar
Aardwolf
Default Retard stock cam?
Is there to little over lap to both with retarding the stock '88 cam? I need to replace my balancer and thought to myself, while I'm there why not see if the cam could be tweaked a little. Any experience with this? I'd like better top end.
Old Apr 13, 2009 | 09:32 PM
ultraviolet70's Avatar
ultraviolet70
IMO not worth effort for the minimal if any improvment. You'll also find there is huge difference in the amount of work between a balance replacement and a timing set replacement.
Old Apr 13, 2009 | 09:41 PM
Aardwolf's Avatar
Aardwolf
I plan to do the timing chain while I'm there as well. It's likely to need it and I'd like to put in a new cam but it's just not going to be in the works for awhile.
Old Apr 14, 2009 | 11:03 AM
redrose's Avatar
redrose
Default off road only
'old school' is to retard the cam for more top end power, but your oem CAM timing is oem retarded 8* (or more) from most efficient fuel mileage/power for emissions... for off-road use, advance the cam to get intake opening centerline at abt 106* ATDC...improvement in fuel economy and power is noticeable.
Old Apr 14, 2009 | 02:16 PM
tpi 421 vette's Avatar
tpi 421 vette
Personally, I would waste your time changing cam timing with a stock cam. A cam swap would be the way to go. You can optimize any configuration better with a aftermarket cam.
Old Apr 14, 2009 | 02:40 PM
pologreen1's Avatar
pologreen1
I seen a thread on corvette action center (I think from churchkey) from a while back that talked about it, soem said it made a difference try to google it.
To Retard stock cam?
