Thought I was done, NOT! More problems
Old Apr 13, 2009 | 10:21 PM
ch@0s's Avatar
ch@0s
Default Thought I was done, NOT! More problems
With Jons help (FIC) I was able to figure out how to install my fuel injectors.
My car was ready to start today.
I turned the key on to set the fuel pressure but it stayed at 50 no matter what I did.
It needs to be at 44 but I screwed the AFPR all the way in and out and it stayed at 50psi.
I thought maybe I had a bad Gauge so I called Firevette and he came over with his.
The first thing we noticed was the battery was almost dead so we hooked up jumper cables to my wifes car.
It turned over but the belt made noise.
We found a locked up air pump.
can this thing be gutted out somehow?
We pulled the belt, the engine started but was running rich.
We checked the pressure with the engine running and the AFPR vacumm line off.
IT WAS 50PSI again! Firevettes gauge made no difference.
So to sum it up:
I have a bad battery (easy fix).
Can the AIR pump be gutted?
WTF is up with my fuel pressure?
Old Apr 13, 2009 | 10:26 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Chaos call Control. (who's old enough for that show? Anyway you have a bad AFPR or the cup is assembled wrong. Even if you got a giant pump the reg should break the pressure and return the fuel to the tank maintaining what its set at. Its rich because you have too much rail pressure. There is a pump delete pulley but gutting it is possible Wheres agent 86 he knows how to gut one
Old Apr 13, 2009 | 10:37 PM
ch@0s's Avatar
ch@0s
ME! lol
I love that show!
That's what I was thinking but hoping not the case.
I would like to gut the AIR pump if it's easy beacuse I can order a new one for $48.
Thanks! you are my hero!
Old Apr 13, 2009 | 11:03 PM
ch@0s's Avatar
ch@0s
Is that possible?
Old Apr 14, 2009 | 12:08 AM
FICINJECTORS
Supporting Vendor
Originally Posted by ch@0s
Is that possible?
i don't know which type you have but basically there is a adj screw that tightens the spring against the valve.. the valve should move freely with the spring against the diaphragm. there should be something up top that when you screw in the adj screw it tightens the spring. sounds like thats not happening with yours.
Old Apr 14, 2009 | 12:16 AM
ch@0s's Avatar
ch@0s
I have a TPI parts AFPR it comes with a washer that fits over the spring hat and screws. I think they are installed correctly??
I put the washer on the spring and the cap and screw in...*shrug*
Old Apr 14, 2009 | 06:50 AM
FICINJECTORS
Supporting Vendor
so you have the stock valve still in the rail? it must be clogged on the bottom. take it out and make sure the hole in the bottom is open. Is the diaphragm in right, not upside down or something. I don't know because i never had one do what yours is doing. When its working properly a few turned either way changes the pressure quickly
Old Apr 14, 2009 | 10:46 PM
ch@0s's Avatar
ch@0s
I nstalled a new regulator today.
looks like that was the prob not sure yet tho.
I also ordered a smog pump 46 bucks at auto zone.
Old Apr 17, 2009 | 02:56 PM
ch@0s's Avatar
ch@0s
Default Started it yesterday.. runs like c**P
so, I put the new regutor in adjusted fuel pressure to 46 psi
tuner sudgested 44 but the screw hits the plenum at 46
set the timing to 6 degrees
and it runs very bad(missing and no power)
I drove it around the block and put it away
I was really tempted to kick it a few times
Old Apr 17, 2009 | 03:04 PM
FICINJECTORS
Supporting Vendor
before you kick the s**t out of it.. Did you tune the ecu for 26lb injectors?
Old Apr 17, 2009 | 03:10 PM
ch@0s's Avatar
ch@0s
I gave the tuner the part number .. it does not apear to be running rich
but it did for a minute when we first started it and ajusted the regulator
maybe the plugs and o2 were fouled like what happened to Firevette
Old Apr 17, 2009 | 03:13 PM
FICINJECTORS
Supporting Vendor
just for kicks, those injectors are 24lbs at 39.15.. you set the fuel pressure at 44, was that with the vac hose on or off, if the hose was on it really is 49, go set the reg at 36 with the hose on and see how it runs,, does it idle smooth? you say it runs bad, describe it
Old Apr 17, 2009 | 03:26 PM
ch@0s's Avatar
ch@0s
It's set at 46 Vacumm off
I can't go lower the bolt hits the plenum
It's missing really bad and has no power
Old Apr 17, 2009 | 03:27 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Ive been thinking about it, something isnt right with that regulator. It should have dropped below 46, even though it hit the plenum we had that thing way out.
Old Apr 17, 2009 | 03:36 PM
ch@0s's Avatar
ch@0s
It's a new diaphram
the regulator is just the hat and screw
Im thinking of cutting the head off that screw an using a shorter one
I also want to bump up the timing to 8 replace the O2 and ck the plugs to see if they are fouled
Old Apr 17, 2009 | 03:44 PM
FICINJECTORS
Supporting Vendor
It's a new diaphram
i thought you were fixing that you have too much fuel pressure making those injectors flow too much... they are 24 at 39 you are close to 49fp. making the injector over 26lb,, I have no idea what constant the tuner put in your computer either, see if you can find out and get the FPR working correctly
Old Apr 17, 2009 | 04:07 PM
ch@0s's Avatar
ch@0s
i have this injector
http://www.witchhunter.com/flowdatapix/b0280155865.jpg
so that is 25.3 at 43.5
the tuner wanted it set at 44 thats 25.4
and set at 46 they will flow 26.1
will that make it run Bad?
To Thought I was done, NOT! More problems
Old Apr 17, 2009 | 05:29 PM
FICINJECTORS
Supporting Vendor
i
t should not if the tune is right.. are you setting the pressure with the hose on or off
Old Apr 17, 2009 | 05:50 PM
ch@0s's Avatar
ch@0s
with the vac hose off
ok, I am going back to maybe timing or spark
Old Apr 17, 2009 | 06:24 PM
AKS Racing's Avatar
AKS Racing
Do not shop the head off. Remove the hat and screw from the AFPR. Unscrew the adjustment screw, and remove ~3 threads worth of material. Clean the thread up and reassmble everything. You should be able to back it out far enough to get the lower FP (unless you have a really thick spacer between the diaphragm and the adjustment screw).
Pics are always a good thing (of the AFPR installed, then of the AFPR parts).
Aaron
Geez, it is raing like a SOB up here....
