Switching and porting plenums
Old Apr 15, 2009 | 10:25 PM
rodj's Avatar
rodj
Originally Posted by pologreen1
when you buy runners and stuff 89 is not all by itself,
Still wrong , when using stock parts need correct plenum
Stock 89 plenum does not work on 90- 91 cars.
Once you go aftermarket on the runners ,then it doesn't matter because you can delete the CSI
Old Apr 15, 2009 | 10:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Plenum work looks good there, nothing wrong with a strong TPI car.
It wont be a superram but personally Ill take the hit on upper hp over having to mess with that lid. Lots of low end torque on the street can be fun without breaking speed limits or winding it up to the moon to get your jollies.
Ditto on laying on your back under a C4. I wont miss is a bit.
Old Apr 15, 2009 | 11:30 PM
bomar76's Avatar
bomar76
I just want to see this cast iron plenum.
Old Apr 16, 2009 | 10:27 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I never said the plenum was cast iron. The E86 HEADS are cast iron. I was asking if that made a difference. 89 is different so I did not know if the E styles were different.
Old Apr 16, 2009 | 11:02 AM
floridamale's Avatar
floridamale
[QUOTE=Harley Davidson;1569700131]What year plenums for the L98 are interchangable. Say would a cast iron 86 plenum fit a 1990?
In your first post you kind of did ask that but you might of been thinking heads
You can buy blockoff plates for any year cold start injector
Old Apr 16, 2009 | 12:54 PM
M.J.L.'s Avatar
M.J.L.
If I put these on a stock TPI, will I see any gain? They are SLP runners. Look alot different than the stock oens.
http://www.mamotorworks.com/corvette?frame=3.8395
Old Apr 16, 2009 | 02:50 PM
engle1147's Avatar
engle1147
Yes those are the same runners I'm slapping on the new build. The SLPs are good for a few hundred extra RPM (even on a stocker) since they have the area cut down between the tubes from the manufacturer....basically the idea is this gap produces a "shorter" runner effect... typically the shorter the runner the higher the RPM band is effectively moved....which is why you hear about people cutting the back out of the runners and grinding the guts out only to leave a small extension before the intake. Below is a pic of the SLP runner (on the right) I finished porting the other day....still needs some work though. The one on the left has had some light porting which is how I purchased it from another CF member.
Old Apr 16, 2009 | 03:07 PM
M.J.L.'s Avatar
M.J.L.
I am going to loose low end torque going with the SLPs and not gain any power....just moving it up?
Old Apr 16, 2009 | 03:25 PM
engle1147's Avatar
engle1147
Will lose a little but but remember these are TPI setups (as the saying goes "makes a great motor for a truck") they make tons of torque so you won't even notice the very small low end loss.
Old Apr 16, 2009 | 03:33 PM
engle1147's Avatar
engle1147
Take a look at this link and you'll get a better idea of what will result. The motor in the link is a 383 so your # won't even come close to those but notice how the torque/Hp curves shift between the setups....expect a similar but less dramatic curve shifts to occur if you go this route.
http://www.superchevy.com/technical/...t_results.html
Old Apr 16, 2009 | 03:49 PM
M.J.L.'s Avatar
M.J.L.
I am get the SLPs and port the plenum. How much torque/hp increase can I expect overall?
Old Apr 16, 2009 | 06:48 PM
rodj's Avatar
rodj
You will not " notice" any loss of bottom end.I went to a siamized base, SLP's and a ported plenum.
Improved my 60 ft times and lowered ET at the track.
The dyno will "show" a change but in real terms starting with 330ft/ lb you won't know it
Old Apr 16, 2009 | 06:57 PM
  #33
engle1147's Avatar
engle1147
I've owned a set of the SLP runners before and you can notice the SOTP difference.
Tough to say...if you read their ad it says "up to 20 hp" so it depends on your application.....with all the porting maybe the full 20 hp. As mentioned before if you remove a restriction there will be another down the path so in a perfect world you'd want swap all three components (plenum, intake & runners) to hi-flow stuff....of course a good set of heads would help too. If you get a "SLP" sticker kit expect to gain ~ 20+ hp once you stick'em to the car
I'll PM you one other option which may work for you.
Old Apr 17, 2009 | 07:37 AM
  #34
M.J.L.'s Avatar
M.J.L.
Thanks for the pm! That was svery kind of you to takae the time. I am definatley looking into that.
