Multiple Codes - ECM Failing?
Old Apr 14, 2009 | 03:21 PM
jimg's'93's Avatar
jimg's'93
Default Multiple Codes - ECM Failing?
Within the past 2 months I replaced my opti (yes, a very cheap one I say with head bowed) and replaced my injectors. She ran like a top for about 2 weeks after the opti replacement, but now misses, runs roughly, poor throttle response and a very rich mixture.
The codes I'm pulling are:
DTC 33 - MAP High Volt/Low Vac
DTC 36 - Dist. Faulty High or extra low res pulse
DTC 72 - Gear selector switch circuit
DTC 74 - NO IDEA??
I will be testing these circuits for the MAP and Opti this weekend to see if indeed there are component issues, but what is a DTC 74? It's not listed in my FSM at all.
Also - I'm concerned I might be losing my ECM as the gear selector and O sensor codes have intermittently shown up and disappeared over the years.
Any thoughts to keep me focused in a proper direction here? BTW, I have no Tech 1 or similar, I use a good old Muti-meter.
Thanks all.
Jim
Old Apr 14, 2009 | 10:40 PM
jimg's'93's Avatar
jimg's'93
Well, thanks for the overwhelming responses. First time I've ever posted on the 'scan & tune' side. I did replace the MAP sensor today and she runs beautifully. Let this post die.
Old Apr 15, 2009 | 10:27 AM
Epimax's Avatar
Epimax
Here ya Go!
I don't get over here that often either.. Stopped in looking for a Tech-1
Old Apr 15, 2009 | 12:19 PM
jimg's'93's Avatar
jimg's'93
Thanks Epi! Curious as to why that's not in my FSM, but I've got it now. I did have a failing battery just before I replaced the opti. That must be how that 74 posted.
Thanks again!
Old Apr 15, 2009 | 02:52 PM
Epimax's Avatar
Epimax
Thanks again!
You Bet! I've got the 2 volume FSM at home, but I use the alldatadiy.com site as well. It's an online service and seems to have the same info as the FSM, -as well as technical bulletins, etc, and with the search function it's a lot easier to find what you're looking for too!! That's where I pulled up the Code 74 info earlier!
I use it for all the cars!
Old Apr 18, 2009 | 03:50 PM
jimg's'93's Avatar
jimg's'93
Looks like that site could be of value. Sometimes it is rather a PITA finding some info in my FSMs.
Thanks again!
Old Apr 20, 2009 | 09:21 AM
Epimax's Avatar
Epimax
Thanks again!
You Bet!
To Multiple Codes - ECM Failing?
