Tune for a small cam
Old Apr 15, 2009 | 12:24 PM
1989vette's Avatar
1989vette
Default Tune for a small cam
I'm going to be putting a new motor with a small 218/218 duration at 050 with about .470 lift with tfs 62cc heads in the car in the next few weeks. Its going to be a flat tappet cam, which requires a break in period of 20 mins at 3k rpm. Can this breakin be run on the stock tune? Should i increase any injector pw or maf tables? I only worry that the 3k rpm for a sustained period in open could lean out a few cylinders and burn them down.
Car is an 89, and will have a ported tpi intake sitting on top with stock ci.
Old Apr 20, 2009 | 10:20 AM
89onlyZ51's Avatar
89onlyZ51
If you haven't changed your injector size, you should be OK without a tune for break-in since you're MAF. You'll want a tune for the PE/higher RPM ranges for regular driving.
