hard starts when hot
Old Apr 16, 2009 | 07:02 PM
chips88's Avatar
chips88
Default hard starts when hot
hard starts when hot after running when motor starts seems to be flooded checked fuel pressure with gauge okay does not drop
Old Apr 16, 2009 | 07:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Could be leaking injector(s). Do you have a fuel pressure gage ??
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Apr 16, 2009 | 07:30 PM
AGENT 86's Avatar
AGENT 86
I see you altered your post while I was typing. You have zero fuel pressure loss ?? How long did you test it ??
Old Apr 17, 2009 | 11:53 AM
cmcbunch's Avatar
cmcbunch
Alotta times this can be solved by upgrading to a gear reduction starter and/or checking you starter cables/replacing them with a heavier gauge cable. Most every car I've ever worked on had insufficient gauge wiring in critical high load areas. Also triangulating your grounds and replacing you alternator cable with a heavier gauge one that runs straight to the battery instead of the starter also helps.
You can buy a high torque gear reduction starter for pretty cheap nowadays. They'll turn over 14:1 big blocks when they're hot and they lighter, more reliable, and more compact than those heavy *** truck starters they were putting on these cars.
Old Apr 18, 2009 | 09:34 PM
dallas3246's Avatar
dallas3246
Cruising
Had a similar problem recently, depending on what you mean by 'hard start.' Mine would start but die instantly or run very rough. Replaced the ICM and it seems to have fixed it.
Old Apr 18, 2009 | 10:09 PM
rodj's Avatar
rodj
waiting for Mr FIC
http://forums.corvetteforum.com/c4-t...lp-please.html
Old Apr 18, 2009 | 10:59 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Originally Posted by rodj
88's don't really have bad injectors on the electrical side, just mechanical.. Two things, the injectors just might be clogged, even 2 or 3 could keep it from starting easy. But, the OP says he smells fuel.. So I would check the cold start valve for leaking. The easiest way to do this is with compressed air and a air chuck with a rubber nozzle. Remove the CSV and with no juice to the valve blow air into the top, if it leaks you will feel air come out the bottom. Then energize the valve with 12 vlts. Air should flow easily out the bottom. If it checks out reinstall and let us know.
Old Apr 20, 2009 | 06:33 PM
chips88's Avatar
chips88
checked fuel pressure on fuel rail, key on gauge goes to 40 psi, start motor gtauge goes to 35-36 psi, run motor 15-20 minutes shut off,gauge drops to 8-10 psi, start motor turnsa over like its flooded then starts.
Old Apr 20, 2009 | 06:43 PM
FICINJECTORS
Supporting Vendor
You got a leaky injector or a leaky CSV,,
Old Apr 24, 2009 | 07:30 PM
chips88's Avatar
chips88
Default hards starts when hot
checked injectors with volt meter all injewctors between 15.8 to 16.
Old Apr 24, 2009 | 07:33 PM
chips88's Avatar
chips88
[QUOTE=chips88;1569838356]checked injectors with volt meter all injewctors between 15.8 to 16.
will check csr valve next
/QUOTE]
Old Apr 24, 2009 | 09:02 PM
FICINJECTORS
Supporting Vendor
[QUOTE=chips88;1569838387]
/QUOTE]
you have to remove it to check it.. it is not a injector its just a solenoid controlled valve, it either opens or closes, the coil is a low impedance and it should read about 3 ohms.. Do you know how to check it for leaks? go back to post 7
Old Apr 29, 2009 | 07:55 PM
chips88's Avatar
chips88
[QUOTE=FICINJECTORS;1569839262]
removed csv will test 4-30-09 and let you no, THANKS FOR THE HELP CHIPS 88
Old Apr 30, 2009 | 06:23 PM
chips88's Avatar
chips88
[QUOTE=chips88;1569900606]
checked csv no air going threw valve, put 12 volts to valve no air coming out bottom of valve, called chevrolet dealer, SAYS NO NEW VALVES AVAILABLE, WHER CAN I BUY NEW VALVE.
Old Apr 30, 2009 | 07:36 PM
FICINJECTORS
Supporting Vendor
[QUOTE=chips88;1569913272]
they are the hardest thing to find.. The aftermarket ones that I have bought do not fit right.. Best thing to do is eliminate it by having the chip reprogrammed for a cold start using the injectors like 89 and up
Old May 1, 2009 | 12:12 PM
mayan46's Avatar
mayan46
[QUOTE=FICINJECTORS;1569914166]
Hi Jon. I have a 1988 Corvette and I want to eliminate the cold start valve. I'm having the same problems as above. Could I change out the chip with one from a 1989 Corvette? Where can I find the block offs for the cold start valve? Thanks for any info. David
Old May 1, 2009 | 12:20 PM
FICINJECTORS
Supporting Vendor
[QUOTE=mayan46;1569922413]
not sure if you can do the 89 chip in a 88, I have sent my chips to alvin to write out the csv and buy one of these..
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
To hard starts when hot
Old May 1, 2009 | 12:36 PM
shamdave's Avatar
shamdave
BUT did you check the volume? mine did the same thing...drove me nucking futts If you hit the fuel Volume chacker on your FP tooland it dies it is a bad fuel pressure regulator. Rule that out first before you start throwing money at it.
My FPR made 2 fuel pumps go bad so you may have to replace the pump if you are nt getting the volume it needs to run properly
Old May 1, 2009 | 03:17 PM
mayan46's Avatar
mayan46
[QUOTE=FICINJECTORS;1569922504]
Thanks for the lead on block off plate. There is someone in my town that can program the chip. I just have access to a 1989 model that I though would be easier. Thanks again. David
Old May 1, 2009 | 11:39 PM
Noobster's Avatar
Noobster
From: My Give A Dams Busted The Bend Me Over State N.J
I have the same dam issue. 1988
