Auto Transmission Question
Old Apr 17, 2009 | 08:50 AM
seajayiii's Avatar
seajayiii
Default Auto Transmission Question
I have been driving my '90 Coupe for a little over two years now. To the best of my knowledge, it's all stock (L98 Auto). On a recent trip, I noticed on the GPS that the speedo is not accurate (GPS reads 70 ... speedo reads 60). Now, that means while I am driving in local traffic here in Southeastern NC (which can be a real PITA), the Vette won't shift into high gear until the speedo reads about 41 MPH which in reality is probably approaching 50, and the OD won't kick in until the speedo reads 44 MPH (about 53 MPH). That's on a normal, average start ... say from a traffic light. It's been that way since I bought the Vette. A while back, I had some work done on the buggy, and the mechanic told me that there's an aftermarket chip in the car. I did not know that. Would the chip affect the speedo reading and transmission shift patterns or are my actual speed and shifts normal? Can the speedo be recalibrated and if so, would that change when the tranny shifts? How can I tell if it's an aftermarket chip? What's it take to return to the stock chip? Would that make a difference?
I really don't mind it too much, particularly on a trip. But tooling around town, it's like I am waiting and waiting and waiting for the car to upshift.
Old Apr 17, 2009 | 09:21 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
I can't answer all your questions,but based upon your statements can tell you: I've also noticed a difference in the GPS and speedometer, can't say which one is greater, as I rely on the speedo. Regarding the performance chip......I do have a Hypertech that I installed about one year after vette purchase. My '91 is an auto with 3.07 and before the install OD shift under normal driving was at 40mph (speedo) and after chip, under same driving conditions the shift point is 44mph(speedo).
Open up the ECM coverplate where the prom is located and if a Hypertech (now there are many chips out there) it probably a piggyback design that mates to your stock prom. And if a piggyback design you should be able to read "Hypertech and part # after removing the coverplate. IF a Hypertech and piggyback design you can remove the stock chip and reinstall after removing from the ECM. Now, my ECM is located in engine department right to the left and over the battery, not sure if yours is the same. I do have a efile of the installation instructions for the Hypertech chip if you would like a copy. If so PM me your email address and I will send posthaste.
Good Luck and
SAVE THE WAVE
Old Apr 17, 2009 | 09:26 AM
seajayiii's Avatar
seajayiii
PM sent ... Regards.
Old Apr 17, 2009 | 09:37 AM
vetteman42's Avatar
vetteman42
Email sent!
Good Luck!
SAVE THE WAVE
To Auto Transmission Question
