major pain
Old Apr 18, 2009 | 03:14 PM
gmc's88vette's Avatar
gmc's88vette
Default major pain
Just need to vent frustrations a bit. While completing my coolant system flush by way of removing thermostat and using shop vav to blow thru the system, I started reinstalling the thermostat. One bolt would not go all the way in. You could hand start the bolts so it was not cross threaded. Tried a few times to get it to go all way in but no luck. Blew down in the hole and checked fro debri but nothing there. Used awl and checked depth of hold and bottom was about the distance of the nut. Nothing there. Looking down in hole about 1" down threads looked rough. Decided to use tool to clean up the threads as it must have had a thread break off. ?? Ran tool in and it stopped,backed it up ran in again and it stopped, ran bolt in and it stopped. This time going in with the thread clean up tool decided to put more pressure to the tool. The S.O.B broke off. Dammmmm! Now i got the problem of removing that piece of tool and probalby end up having to use helicoil. Very frustrating!!!!!!!! If anyone has good rec's here I'm listening.
Old Apr 18, 2009 | 06:04 PM
Aardwolf's Avatar
Aardwolf
Bummer! You could just cut the bolt down, they used much longer bolts in most places than what are needed. I've been cutting them down, damn extra weight.
Old Apr 18, 2009 | 06:57 PM
gmc's88vette
Now why didn't i think of that to begin with. Would not have this prob. now if I had. Nice idea.
Old Apr 18, 2009 | 11:42 PM
383vett's Avatar
383vett
Too late now, but instead of cutting the bolt, it would be easier just to use a washer.
To major pain
