#4 sparkplug arcing off header
Old Apr 20, 2009 | 02:57 AM
AZC4Guy's Avatar
AZC4Guy
Default #4 sparkplug arcing off header
New spark plug wires... Blue Max. The end of the spark plug is VERY close to the header... may the thickness of a couple of credit cards.
I need to fix this... suggestions?
Thank you!
Old Apr 20, 2009 | 07:56 AM
runner140*'s Avatar
runner140*
Thank you!
Don't know about a fix, but I used a couple of zip ties to move plug wires away from metal parts. BTW, the zip ties are still attached after about four years on my daily driver.
Old Apr 20, 2009 | 09:35 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You might need to buy those insulated plug wire header socks to protect the wire, too. If it's arcing, isn't the wire already considered compromised, though?
Old Apr 20, 2009 | 10:12 AM
psd_bullitt's Avatar
psd_bullitt
I had not heard of these 'socks' before. Interesting.
Old Apr 20, 2009 | 10:55 AM
c4cruiser's Avatar
c4cruiser
New wires shouldn't be arcing even if it's touching metal. Pull the plug and check for any signs of cracking on the white insulator or if the tip is loose. A cracked insulator will allow current to pass from the center conductor to ground.
Old Apr 20, 2009 | 12:44 PM
onedef92's Avatar
onedef92
They're called "KoolSox." You can find them at speed shops and specialty performance stores. I've also seen them online at Mid America Motorworks (MAM).
Old Apr 20, 2009 | 12:52 PM
Demonic85's Avatar
Demonic85
I bought a set of those "premium" blue max wires from NAPA and my exhaust absolutely cooked them. I put a set of cheap $20 autozone wires and havent had any problems since
To #4 sparkplug arcing off header
