Need some help???
Old Apr 20, 2009 | 04:11 AM
curtis74's Avatar
curtis74
Default Need some help???
I got my stock '95 Corvette and I was thinking about doing a few simple upgrades. I did have a couple questions however. I was thinking of adding a new throttle body. What is the best to use with a stock set-up, a 58mm or 52mm? Also I would be adding a new mass flow sensor as well and possibly a cold air set-up as well. With adding these three things to a stock car, what additional tuning would have to be done if any?
I'm an old C3 guy so this is all new to me. Thanks for the help!
Old Apr 20, 2009 | 04:29 AM
toptechx6's Avatar
toptechx6
Larger throttle body and MAF will gain little or nothing on a stock engine, aside from appearance you will gain as much by cutting the stock filter lid and installing a K&N filter as you will from the cold air intake.
You didn't say what transmission you have but if it is an A4, lower rear gears give the best bang for the buck when it comes to seat of the pants improvement.
Old Apr 20, 2009 | 04:48 AM
curtis74's Avatar
curtis74
Excellent to know! I would hate to spend all that money on those upgrades for nothing. Yes it does have an A4. What is a good gear set to run?
Old Apr 20, 2009 | 04:55 AM
Weav's Vet's Avatar
Weav's Vet
I did this (2.59 down to 3.07) to my '96 and it is a totally different car. I also put in a higher stall converter (2800) at the same time I did the gear swap. The cut lid on the air filter is a cheap and easy mod. Unless you are planning some engine mods down the road you're wasting your money on a larger TB. Get some TB cleaner and clean up the OE unit. Take it apart and clean up the inside good. This can add a little pep to the engine and improve idle quality.
Enjoy your '95!
Old Apr 20, 2009 | 05:01 AM
toptechx6's Avatar
toptechx6
First verify what ratio you have now by checking RPO codes, on the label under the center console. (The Technical Summary at the top of this section has a lot of information to help)
If you have the stock 2.59 set up, the 3.07 performance ratio makes a nice improvement as Mike said. If you already have the performance gears, consider 3.54, some guys even like 3.73, but for me they were too steep on the freeway.
A higher stall converter complements the gears, again as Mike pointed out.
Old Apr 20, 2009 | 07:44 AM
curtis74's Avatar
curtis74
I already know that I have 3.07 gears. My only issue is that I still want it to be drivable at high speeds.
Old Apr 20, 2009 | 08:09 AM
toptechx6's Avatar
toptechx6
I have 3.45's in my 93, but the ratio is not available unless you change to the D44 rear axle that comes standard in manual cars, 3.54 is a comparable D36 ratio that is very similar.
Since you have 3.07's you have a 3 series carrier and can use a standard thickness ring and pinon set in your existing D36 rear end. My 93 has good launch and is still not obnoxious on the freeway, my previous 3.73's were a little too steep for my taste at freeway speeds.
Old Apr 20, 2009 | 08:30 AM
curtis74's Avatar
curtis74
Great information man! I don't want to get too crazy with this car. That's what my '74 is for. It has 3.73 gears and is a monster on the highway. I got the '95 for more practical use, but at the same time if I can do a few subtle changes to enhance it then why not. Again, thanks for the feedback. This is the kind of stuff I need to know about these cars.
Curtis
Old Apr 20, 2009 | 09:17 AM
Epimax's Avatar
Epimax
Excellent Advice! I cut the stock filter lid and added K&N...
This mod was budget friendly!
To Need some help???
