Oil Leak
Old Apr 21, 2009 | 01:47 PM
jojolt1's Avatar
jojolt1
Default Oil Leak
Hey, everyone,
Hope you are all well ! Got a problem, oil leak on the passenger side of my LT-1 would like some hints on where to start looking ?
Thanks,
jojo
Old Apr 21, 2009 | 02:38 PM
vetteboy95's Avatar
vetteboy95
Check the intake manifold, front and rear are known for leaking. There are a countless number of us here that have repaired this area. Also the pan gasket and I know you said passenger side but I just did the oil filter adapter too as that was leaking.
Old Apr 21, 2009 | 02:42 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Timing cover seal is another usual suspect on these engines.
WW7's Avatar
WW7
Intake or valve cover gasket..WW
Old Apr 22, 2009 | 12:13 AM
formul89's Avatar
formul89
Maybe the rear main seal?
My '94 is leaking oil from the converter inspection cover area.
Old Apr 22, 2009 | 03:30 PM
TWISTERUP's Avatar
TWISTERUP
I'll post this since I looked at your profile and you have a '96 OBD2....I thought mine was the front crank seal...cleaned the area and rechecked turned out it was the crank position sensor O-ring...could be any of the other areas mentioned depending.
To Oil Leak
