dragstrip let down
Old Apr 25, 2009 | 01:45 AM
Camaro350z28's Avatar
Camaro350z28
Default dragstrip let down
well i finally got back to my dragstrip after a year and a half.
last time out i posted a 13.6 at 103 with a 2.1 60'
now my car is cutting out everywhere, can only have throttle, ran 2 14.2's at 100, with 2.3 60' times. my brake like was flashing down the track randomly? dont get that? changed my FPR today and it fixed my long start problem. gonna hook up gauge tomorrow make sure pressure is good all the way. guess maybe a tuneup is in order?
i pulled plugs they looked good, wires look a little old i guess i can check for arc? anything else i should look for? no codes
Old Apr 25, 2009 | 03:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Was the E-brake left engaged?
What is pressure at the fuel rail?
Old Apr 25, 2009 | 09:43 AM
realsass's Avatar
realsass
It's a;ways something isn't it? Keeps us busy!
When she is purring they she should be life is great!
Old Apr 25, 2009 | 09:53 AM
tpivette's Avatar
tpivette
the flashing brake light could be low fluid in the master cylinder. if the level is low, and the fluid uncovers the sensor (like when you launch), this could trigger the light. it could also just be a bad sensor. im assuming you DID have the ebrake fully disengaged
what year is your car? is it MAF equipped? its possible you could have a MAF thats on its way out. my GFs 94' Formula had this problem at the track, and by unplugging the sensor, it regained its performance. i would do that test on the street to see if the problem goes away
it could also be fuel related. do a fuel pressure test by hooking a gauge to the fuel rail and tape it to the windsheild while talking the car for a test drive. go WOT, and if fuel pressure drops, you have your problem
let us know what you find
Old Apr 25, 2009 | 10:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
MAF/Fuel pressure under load.
Old Apr 25, 2009 | 10:44 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I have left the E brake engaged before.
Old Apr 25, 2009 | 11:18 AM
dan_t's Avatar
dan_t
Plenty of fuel? Mine will fuel starve will less than 2/3rd of a tank
Old Apr 25, 2009 | 03:05 PM
Camaro350z28
1994 M6
i had plenty of fuel. 2/3 of a tank actually.
i cant use my ebrake so it hasnt been used in... 2 years.
maybe just a bad sensor then, i have checked fluid. i will do the fuel pressure test today. i sure hope its not the maf.
the thing is it seemed to run great on the street on the way home... maybe its cause im not launching on the street, but it allowed full throttle without cutting out then. 2 runs on the strip and it did it both times.
cars. ill keep ya guys posted.
Old Apr 25, 2009 | 04:41 PM
Camaro350z28
ok well this is lovely, just hooked up the fuel pressure guage, i am getting like 35 psi at idle now. before i changed my FPR i was gettin 42-44..
bout to take it for a drive and see if the psi dumps off.
35 psi is already low anyway right? gonna go get my money back haha stupid FPR
Old Apr 25, 2009 | 05:24 PM
John A. Marker's Avatar
John A. Marker
When was the last time you changed your in line fuel filter???
Old Apr 25, 2009 | 05:41 PM
Camaro350z28
i havent changed it since i bought the car. but i did lose pressure from one FPR to the other, i checked the fuel pressure right before i swapped in new one
Old Apr 25, 2009 | 09:23 PM
bills1985corvette's Avatar
bills1985corvette
Fuel pressure (35) is a little low I believe a 1994 should be between 41 - 47 PSI.
Old Apr 25, 2009 | 11:42 PM
GIANNIP's Avatar
GIANNIP
you might need a new fuel filter
To dragstrip let down
