Hot starting issue
Old Apr 26, 2009 | 12:59 PM
wilsallvette's Avatar
wilsallvette
1st Gear
Default Hot starting issue
I have an 86 that starts fine when cold and usually even when it is warmed up. However, when running errands, about the third time I get in to start it nothing happens. It is usually over 210 degrees and has set for a few minutes. I hear only relay clicks when I hit the start position on the ignition switch. I have replaced the start relay, starter and ignition switch. The clutch switch is no longer available, so I haven't got to it yet. I always starts again once the temp drops below 190 or 180 degrees. Any ideas?
