Passive Keyless Entry question
Old Feb 2, 2002 | 05:46 PM
Guest
Guest
Posts: n/a
Default Passive Keyless Entry question
I don't know what I did (except for following the instructions :bb), but my PKE works and I love it! Question, though, can it be programmed somehow to unlock both doors at the same time - instead of just driver's door? It's a real pain in the **** to manually unlock the passenger's door when someone's trying to open the door at the same time....grrrrrrrrr. Thanks in advance.
Old Feb 2, 2002 | 07:33 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Passive Keyless Entry question (Mairi)
Put the key in the ignition, turn on, but donot start.
Hold down the door button (FOB) until the locks cycle. It may take a few shots, but you'll get it. :cheers:
Old Feb 3, 2002 | 10:17 AM
Bartman's Avatar
Bartman
I could be wrong but I don't believe that the PKE will ever automatically unlock the pass side door without pressing the unlock button. :confused: My driver door unlocks when I walk up to the car and I have to use the button for pass.
Bart
Old Feb 3, 2002 | 10:58 AM
Guest
Guest
Posts: n/a
Default Re: Passive Keyless Entry question (Bartman)
Thank you Lou and Bartman for your responses. :) The reason I thought it could be done is this dandy sticker I found in my owner's manual that states (pertaining to Passive Keyless Entry System), To switch between unlocking one or both doors: With key in the ignition, hold "DOOR" button for more than 2 seconds. So I'm thinking, "GREAT!" It took me long enough to get the driver's door programmed (don't laugh) - so I didn't want to end up screwing up the driver's door for naught if this isn't what the sticker was referring to. I'm going out in a bit and trying it.
Old Feb 3, 2002 | 11:52 AM
Red Dwarf's Avatar
Red Dwarf
Mairi,
I gave you bad info regarding the PKE. When you put the key in the ignition you donot turn the the key "on". Press the door button & the locks will cycle either to open the drivers door or both doors.
Sori about the "Bum scoop", hope it didn't cause you any problemsThank you Lou and Bartman for your responses. :) The reason I thought it could be done is this dandy sticker I found in my owner's manual that states (pertaining to Passive Keyless Entry System), To switch between unlocking one or both doors: With key in the ignition, hold "DOOR" button for more than 2 seconds. So I'm thinking, "GREAT!" It took me long enough to get the driver's door programmed (don't laugh) - so I didn't want to end up screwing up the driver's door for naught if this isn't what the sticker was referring to. I'm going out in a bit
Old Feb 3, 2002 | 03:47 PM
Jack78's Avatar
Jack78
Default Re: Passive Keyless Entry question (lou sylvestri)
Mairi - you're doing better than I am..... I've gotten to where my PKE will LOCK the doors when I leave the car, but it won't open anything when I approach - nor does hitting the "door" button unlock the pass door.....I've reprogrammed the #$@^% thing several times per the owners manual, but no luck yet :(
Old Feb 3, 2002 | 05:22 PM
Guest
Guest
Posts: n/a
Default Re: Passive Keyless Entry question (Jack78)
Ummmm........ I gave up on the passenger door unlocking automatically when the driver's door does, so don't feel so bad Jack. I decided I'm fortunate that the driver's side locks when I walk away and unlocks when I walk up... I'm not going to mess with a good thing. I got it programmed purely by accident to begin with (instructions in hand, still was scratching my head). Next time I have it up at my mechanic's (who's a 'vette owner himself) I'll have him give it a go.
Old Feb 3, 2002 | 08:58 PM
dtw50's Avatar
dtw50
My '96 automatic will unlock both doors when I get within range. It's been that way since I bought it, so I'm not sure how to program it.
Old Feb 4, 2002 | 11:34 PM
Admiral Fairway's Avatar
Admiral Fairway
This is the procedure for getting the passenger door to unlock with the drivers door.
1. A valid transmitter must be in range.
2. The key is in the ignition and the ignition is OFF
3. The DOOR button on the remote is pushed for longer than 2 seconds.
When you do these things the doors will lock and then unlock (hold remotes door button until they lock and then unlock) to signal that the setting has been changed.
This is according to the '94 service manual.
To Passive Keyless Entry question
