1985 manual trans questions
When going from forward into reverse (after lifting the lock out ring) it's easy.
Is this normal? Is there something to check? Or adjust?
2.) This has happened only twice, but when I came to a stop sign and went to shift into first gear my clutch petal when completely limp. Right to the floor with no effort. It was hard to get into gear there was some grinding. After a few trys the petal returned to normal operation and I was able to get into first gear.
Is this a sign the clutch master cylinder is going bad? The slave cylinder?
3.) Just a general gripe, why doesn't the FSM give better detail of removing the shifter ****? Like the "T" rod that connects to the Over Drive switch unscrews.
Thanks for everyone's help.
As for FSM info, what section where you looking in, my FSM gives an adequate description.
http://members.shaw.ca/agent86/OD%20Switch.pdf
I though 85's had the OD switch in the shifter plate.
