High pitched noise
Old Apr 30, 2009 | 08:47 PM
Andyman11111's Avatar
Andyman11111
Default High pitched noise
Hey guys. I have an 1988 vette and i would sometimes hear a high pitched noise that increased in pitch along with rpms. It would be very quiet and come on and off. My alternator just failed and im replacing it tomorrow. Im not sure if the two were related. The sound seemed like it was coming from the back of the car but i couldnt really tell since it was so high pitched.
Old Apr 30, 2009 | 09:06 PM
Targa86's Avatar
Targa86
That sound is common with failing alternators. Probably related, if you are replacing the alternator I wouldn't worry about it til you do the replacement, if it goes away than you know that is it. Open the hood idling and listen to it as you open the throttle.
Old May 1, 2009 | 12:24 AM
jfb's Avatar
jfb
That sound is much more common when the battery cables aren't making good electrical connection to the battery. I recommend you remove the battery cables (neg first) and clean the cable lugs, bolts, and battery terminals and replace the cables (neg last).
To High pitched noise
