Ongoing saga
Old Mar 10, 2009 | 12:41 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Ongoing saga
My 93 w/headers runs rich, I have heated o2's.
Replaced FI's and regulator, changed plugs and car started up real quick and then got harder and harder to start.
Just replaced opti a couple of months ago when the radiator left town, I have a Datamaster run and the o2's seem to be all over the place on one and the other is fairly flat, all this is at idle which is 625 and fuel trim of 16.
On the Datamaster the Cloop fuel tmr and fuel enabled are 1 and all the others are 0, spark advance is 25, IAC pos. is 89, BPW mS is 2.25 and 2.35.
Sorry to be long winded, but this is driving me nuts. Idle is high, but I cannot find a vacuum leak.
Old Mar 11, 2009 | 02:03 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Nobody has an idea??
Old Mar 11, 2009 | 02:12 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The reduced back pressure of headers will make the car run rich without a proper tune. Did you change the chip or have it tuned?
Old Mar 11, 2009 | 07:23 PM
mseven's Avatar
mseven
first thing I would do is to see if there are any leaks near the 02's, or the bungs, collectors etc. which could possibly be ''seeing'' air.
where are the two 02's loacted ? does the one that is faily flat respond when actually driving?
iac sounds a tad high if at operating temp (C.L.) I would want it around 40 (open throttle blade more).
what rpm does it idle at ?
what is the fuel pressure set at ?
w/out tuning the only other option would be to reduce FP....until you can get the fueling in the tune right.
Old Mar 11, 2009 | 07:32 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Car idles at 625, temp was 176 and the o2's are located in the collector.
Car has a stock regulator and I forgot 1 detail, it has Bosch 24lb blue tops that Jon from FIC says are matched to stock.
Headers should not make the car run this rich, have had headers on several cars and did not have this problem.
Could the IAC be off and the ECM is correcting by adding more fuel?
Old Mar 11, 2009 | 07:39 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Randy, on our speed density cars, long tube headers do make us run richer. Why? Because the O2 see more air and think, she is running lean, dump more fuel to establish correct AF ratio.
I went from shorty SLPS, gutted cats, to Long Tubes and it needed a retune, on my 93.
Couple questions. What camshaft? What tune do you have right now?
Also, can you send me the datamster file. I will compare it idleing etc to a stock 93, a 93 w/Hot cam and mine with 396 Hot Cam and Long tubes.
Currently I have more cam, but I have files somewhere showing different stages.
If one of your O2's isnt doing anything, check and ensure she is grounded well and has a good constant power source. Remember, its only .1 volts, not much and it doesnt take much for it to be a bad connection.
MSEVEN is correct on checking things out, leaks etc. I had a bad one with no codes, and I run heated also.
Also, how does your idle react cold/hot with and without AC?
Old Mar 11, 2009 | 07:50 PM
mseven's Avatar
mseven
at 625 idle the IAC counts should actually be around 25-30 ish, if I remember correctly the FSM states IAC cts. for std. idle. (40 is what I use for around 850-950 rpm modded car ). is the car basically stock?
At 80+ cts. (@ operating temp. c.l.) that is having the throttle blade closed a bit, I just don't believe that would be the entire cause for rich condition. Have you looked at where is the fuel pressure at ? Was the tune/car originally set up for a 24 # inj.?
it would also be imprtant to know if the other 02 responds properly under normal driving. (.550mv is the crossover point so .650mv is not really rich).
Basically from what you are saying it's also sounding like Jon may have to tame those down for you unless you can tweak the tune.
Old Mar 11, 2009 | 08:01 PM
steve40th's Avatar
steve40th
Also, just ot check, make sure your IAC is good too. Even though you see counts within datamster, those counts are only what the ECM is telling the IAC to do. The actual counts never make it to Datamster.
And you wont get a code for IAC as there is none.
http://shbox.com/1/iac2.jpg
Old Mar 11, 2009 | 09:37 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Ok, I got the tune from PCMforless and it was for FMS 24#. Which I got rid of, the one o2 does not stay a constant value(sorry), it does move up and down some. I have searched high and low for leaks and have found none(doesn't mean there isnt and I will check somemore), the IAC is only about a year and half old. Had to replace it when I accidently stepped on it while cleaning the TB. Cam is a very mild cam, do not know the specs , as the previous owner installed.
I do have the datamaster and I will GLADLY send it to you.
Car started running rich just before I put the headers on, thought it just needed a tuneup.
Have not checked FP, gauge is busted and havent bought a new one yet. Have headers, hiflow cats, cam and stock back and will check the o2 connections again.
THANKS ALL!!!!
Old Mar 11, 2009 | 09:40 PM
steve40th's Avatar
steve40th
THANKS ALL!!!!
Cool, here is my email, Steves396lt1@yahoo.com
I will look and see if I have a lng tube header tune. Alvin will fix it for you I am sure, if need be.
Old Mar 11, 2009 | 09:44 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
THANKS ALL!!!!
hey Randy, call me at 770 888 1662 tomorrow I have a few ideas for you.
Jon
Old Mar 11, 2009 | 09:49 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
email sent, thanks Steve and mseven!!
Old Mar 11, 2009 | 09:58 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Ok Jon, will call you in the am and thanks. Also need your mailing address to send back those other fuel injectors.
Old Mar 11, 2009 | 10:13 PM
FICINJECTORS
Supporting Vendor
randy just call me now, on my cell 770 842 0882 I tvoed american Idol
Old Mar 13, 2009 | 04:14 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Ok, I have some more info. Cleaned TB and reset IAC and now the IAC count is 127. Second, in neutral the car starts busting up about 3100 rpm's and is now running rough again.
Going on Jon's suggestion, does anybody know if Advance or anyone test coils?
Also, the TPS is reading .75 and should be around .54, can anything cause this to be this high other than a bad TPS?
Old Mar 13, 2009 | 04:29 PM
steve40th's Avatar
steve40th
With the IAC count and tps being on the high side, is it possible your throttle body idle screw is opening the blades a little? This can cause both those numbers to be up, as your TPS will cause it to run a little richer, and the high IAC counts is the ECM telling the IAC to open up for more air to enter the manifold. Or is yours an aftermarket throttle body?
Old Mar 13, 2009 | 04:32 PM
engle1147's Avatar
engle1147
The autoparts stores won't test the coils....you can check the resistance (ohm) across the coil and compare your value to someone else's to see if yours is close.
There was a thread "just the other day" about how people are slotting out the mounting holes on the the TPS sensor to attempt to trick/adjust the voltage setting closer to the .54 setting.....this setting which is normally only controlled by the ECM/PCM.
To Ongoing saga
Old Mar 13, 2009 | 04:36 PM
steve40th's Avatar
steve40th
Yes, its easy. You want to turn the tps to the left, top part of tps towards windshield. So, you dremel the holes for the screws and turn her to the left a little, with TTS datamastern on but engine off you can view the tps voltage go down.
Old Mar 13, 2009 | 04:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Blades are completely closed, I checked that. Jon suggested making the hole bigger, going to try that this weekend.
Just curious what is making the car start busting up, but I am going work on the TPS and the IAC first and then go from there.
Thanks guys!!
Old Mar 13, 2009 | 04:55 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Forgot to add, I am also getting oil coming out of the dipstick at 3000+ rpms.
