I have a 1991 c-4 that I race. The car is substantially modified.My problem is the right side wheel protrudes from the body and I don't understand why. The differential attachs in the stock mounting tabs on the chassis.
Are the driver side half shaft typically shorter than the passenger side?
I have that problem with my 85 and I think it's fairly common. What I understand about it is that the body itself isn't centered on the frame. I guess when they drop the body on the frame they don't always get it straight. For a car costing as much as a Vette, they'd think they'd try a little harder to get it perfect!
No but many have reported different rear wheel positions L v R stock.
What cond are the batwing mounting bushes in ?
Bat wing bushings are Prothane and in good shape. The pumpkin section of the differential looks centered in the frame but I haven't measured it for exact location.
It looks like the right side axle hub is farther away from the frame than the left - guess I need to take it apart and get serious about it. Thanks for taking a minute to think about it.
