another sorry FX#3 question
I have a select-ride light ON.
When it was working I felt the differences, just a little,
PROBLEM: I found myself shifting shock rates as much as shifting gears, I think I'm nuts, this could cause a accident.
Now that the light is on, and I tried once to figure it out with the ALDL, no avail.
Off this stuff goes,
So here are the questions:
some of these shocks are rebulit as per PO. I have to look at the paperwork to see which ones.
If I unplug the brain "behind the seat" ( Anyone with pictures) do I have to take the actuator off the shocks?
can I manually set it in some position and leave it there and not worry?
Or because the light came on, some shocks are at different settings, because tha actuator on that shock is broken.
expert comments?
The actuators themselves can be unpluged and removed from the wire harness. IF you do this however be careful with the rear ones if the wire pulls back into the body you woun't be able to get it back very easily.
The gear at the top of the shock body shouldn't turn more than about 120 degrees. IF it just spins around it is broken.
There is NO need to keep changing the shock settings. I drive every day and don't change mine even once a week.
I tried to answer your question about this problem here back in November of last year.
If you cannot display any of the codes using the paper clip method, I would bet that the FX3 controller is toast or the PROM (chip) is bad.
My suggestion is to either get an 89 Factory Service Manual so you can follow the specific troubleshooting procedure for not displaying SRC trouble codes or have the diagnosis done by a shop that has some FX3 experience.
The 89-91 shock rod gears turn 160 degrees, the 92 and later shock gear turns 90 degrees.
If it's only 3 positions, how does it get stiffer in performance mode, it is already at it's highest position.
