Installing BBK 58mm Throttle Body....
Old May 1, 2009 | 07:41 PM
Targa86's Avatar
Targa86
Default Installing BBK 58mm Throttle Body....
Are there any changes needed to the ECM or fuel system to make this TB work to it's potential or can I just bolt on and go???
Old May 1, 2009 | 07:49 PM
StealthLT4's Avatar
StealthLT4
Unless you have major other mods, should be plug-and-play!
Only effect, really, will be sharper throttle response. Unless you have, again, major other mods, you will reach 100% airflow at maybe 80% throttle plate angle.
Old May 1, 2009 | 07:58 PM
farscape1a's Avatar
farscape1a
how will a BBK 58mm throttle body work on a 383 with extremely ported heads and a lumpy cam?
Old May 1, 2009 | 08:48 PM
farscape1a's Avatar
farscape1a
anyone?
Old May 1, 2009 | 09:13 PM
aboatguy's Avatar
aboatguy
It works fine on my 355 with AI 200 heads, ported intake, 12:1 compression, lt headers etc but I don't know what constitutes a lumpy cam. My cam is a hydraulic roller (23x 23x on a 110 LSA with .615 lift).
Old May 1, 2009 | 09:16 PM
farscape1a's Avatar
farscape1a
Originally Posted by aboatguy
It works fine on my 355 with AI 200 heads and a 23x 23x on a 110 LSA with .615 lift but my idle is not lumpy.
i have the AI 190cc heads! my lift is nowhere near that through. i think i'm in the 57x range. it's been a while, so i forgot. i'm also on 110 LSA. how much power are you putting down?
Old May 1, 2009 | 09:32 PM
aboatguy's Avatar
aboatguy
Its a custom cam that Ron and Phil put together for my combination and need for speed.
I'm not a track guy or dyno racer the corvette is my daily driver. But I know its making more power with this cam than the 280XFI it had last go around, due to how much harder I was spanking my buddies Cobra. He's tried from a dig and various roll speeds, and some mild bolt on stuff, pulleys exhaust etc, but it was bad enough that he finally bought a new B king and he has the faster vehicle.........for now.
I have a 3500 vigilante stall, 3" B&B exhaust and a couple of other power enhancers sitting in the garage, once I get the gumption to pull the tranny again and install it all it will be time to try try again, and if that doesn't work I may have to get a modded busa.
Last edited by aboatguy; May 1, 2009 at 09:37 PM. Reason: Street race haters take note!!!! he lives in one of those aviation neighborhoods with a private runway.
To Installing BBK 58mm Throttle Body....
