1990 L98 valve guides
Old May 2, 2009 | 06:01 PM
cash's90's Avatar
cash's90
Default 1990 L98 valve guides
Who stocks valve guides for L98 alum heads?
Old May 2, 2009 | 06:06 PM
Pete K's Avatar
Pete K
It is typical to leave the cast iron factory guides in place, and machine them for bronze liners. Nearly every local machine shop stocks hundreds of them.
Old May 2, 2009 | 06:19 PM
ChrisWhewell's Avatar
ChrisWhewell
The k-line inserts. Good if done right, but make sure the machinst has the broach for the clearance you want.
I've got a set of Cal-Valves 0.008 oversized stemmed valves. For one set of the heads I'm doing, I reamed the guides out to 0.3510. That allows running stock iron guides. Less heat exchange and more friction than bronze but more longevity. Always a tradeoff.
I'd pop out the iron guides, but my oven isn't large enough to fit the heads.
Old May 2, 2009 | 06:23 PM
Pete K's Avatar
Pete K
I stopped pressing iron guides out of aluminum heads. Last couple of times the new guides would not fit. Then I had to order custom Brodix Bronze guides, at a rediculous price.
Old May 2, 2009 | 06:33 PM
ChrisWhewell
Yeah, I'd like to find a source for Brodix, a liquidation sale perhaps. If you run across one let me know and I'll do the same. My preference is new bronze guides and proper geometry incluidng roller rockers. I'm still amazed at my 92 chev 350 truck at 270k all stock still running strong burning no oil and passing emissions tests with orginal stock cat still on it. Maybe the emissions tests are just a scam.
Old May 3, 2009 | 02:46 AM
cash's90's Avatar
cash's90
Thanks guys. I could not find any sources for replacement guides. I now know why.
To 1990 L98 valve guides
