help with window switch
Old May 3, 2009 | 04:36 PM
DECKBOY's Avatar
DECKBOY
2nd Gear
Default help with window switch
Does any one know how to remove the center console to allow replacement of the drivers electric window switch? The hard part appears to be the console.
Old May 3, 2009 | 08:43 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default switch
What year vette?
Old May 4, 2009 | 12:12 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
yup
remove the top cover of the dashboard, 2 screws by the defroster, and 4 screws under it.
1. remove vertical cover over the dic and switches and radio on the dashboard in the center
2.then 2 screws inside the center console....
3. 2 or 4 screws on the center console,
4.then the switch is screwed to the center.
4A. on the auto, you need to use a pic, and pick out the pushbutton in the shift ****. it pulls straight up
4B.then pop the snap ring off the center inside the shift ****. the **** slides off, and the cover slides up the stick.
When reinstalling, if an auto, make sure the slider for the gear indicator is in the right position, and reinstall
Old May 4, 2009 | 08:12 AM
DECKBOY's Avatar
DECKBOY
2nd Gear
Default window repair
The year is 1986, sorry. Thanks, Dave
To help with window switch
