Water pump math
Old May 4, 2009 | 08:35 AM
ChrisWhewell's Avatar
ChrisWhewell
Default Water pump math
I counted 39 teeth on the gear driven by the cam sprocket, that drives the water pump, and 98 teeth on the cam sprocket.
At engine rpm = 1000, the cam sprocket spins 500 rpm, which means water pump is spinning at 1256 rpm.
anyone know at what rpm the stock pump begins to cavitate ?
